Correct Vacuum Advance for 69 427/400 - NCRS Discussion Boards
  • Chuck G.
    • May 31, 1982
    • 2034
    Am pulling the distributor for a rebuild/recurve. Have a generic vacuum advance on it now. One catalog sells the #360 and says it is correct for my application, while another catalog sells the #363. That catalog states that he #360 is for 68 only. Which is the correct vacuum advance for my 69 427/400 automatic? Thanks in advance. Chuck
  • William C.
    • May 31, 1975
    • 6037
    Re: Correct Vacuum Advance for 69 427/400
    For the 390-400 hp distributor, I have three non-GM references from 1969 calling for the 360 vac unit, for what it's worth. (National Automotive service manual, Motors Parts/Labor and Chiltons Parts/Labor) (926 Dist)
    Bill Clupper #618
      Chuck -
      The chart in the Chassis Service Manual shows the 1111926 distributor using a "C-3955" vacuum advance unit, with specs of 0 advance @ 7" Hg., and 12 degrees @ 12" Hg. Have no idea how this relates to any stamped ID on the vacuum advance unit.
      • William C.
        • May 31, 1975
        • 6037
        For what it's worth, John's specs match the specs for the '360
        Bill Clupper #618
          • 15602
          Re: Correct Vacuum Advance for 69 427/400 *TL*
          Delco-Remy Test Specifications show:
          For 1111926 distributor Vacuum unit should be 1115360. Sounds like we are all singing the same song.
          It also shows the same vacuum unit information John has provided.
          • Chuck G.
            • May 31, 1982
            • 2034
            Thanks for the info, guys. Appreciate it. BTW, a company which is a Paragon of originality sells the 360 as correct, while a Corvette company Centrally located sells the 363 as correct, and the 360 for 68 only. Chuck
