C-2 Vacuum Advance - NCRS Discussion Boards
C-2 Vacuum Advance
  • John F.
    • July 31, 1999
    • 105
    C-2 Vacuum Advance
    I'm a little confused about the proper configuration for the vacuum advance line on a base engine 66 coupe. The Judging manual states that the vacuum advance line has a black hose, with the qualifying comment that the L79 has a chrome line as well. The AIM indicates a combination of chrome and rubber hose for the base engine. Which is correct? Thanks
  • Tom Merkel
    Re: C-2 Vacuum Advance
    John - For what it's worth, my '67 L-79 has a metal 'tube' out of the carb, which transitions to a rubber hose which then terminates at the vaccumn advance 'can', but I don't believe it (tube) was ever chrome.
    tm
      • 43229
      Tom and John-----
      If I recall correctly, for 1966 both 300hp and 350 hp used a chrome vacuum advance line, although there may have been exceptions. The line coming of the carburetor had a short section of hose, then the u-shaped metal line. On the right side of the engine this transitioned to a rubber line which connected to the distributor vacuum control.
      For 1967, I don't think that any of these vacuum tubes were chromed.
      • Gary B.
        • February 1, 1997
        • 7027
        John,
        If you get no other definitive answers today, I can take a look tonight for some photos I took of my 66 L79 before I dismantled it earlier this year. I do recall there being a chrome line, but I can't remember off the top of my head how it interfaces with the carb on one end and the vacuum advance on the other.
        Gary
        • John F.
          • July 31, 1999
          • 105
          Gary - the judging manual indicates that the L79 did have the chrome line. My confusion is whether or not the 327/300 used an all rubber line, or a set up similar to what you have. Joe's comments agree with what is shown in the AIM but do seem to contradict the judging manual.
          John
          • Gary B.
            • February 1, 1997
            • 7027
            John,
            I can't help with teh 300 HP configiuration, but I can let you know if the
            350 HP config agrees with the JG.
            Gary
              John -
              The 300hp used a steel line from the carb to just aft of the painted clip under the intake bolt, but it wasn't chrome.
              • Gary B.
                • February 1, 1997
                • 7027
                L79; Vacuum Advance line
                John,
                My L79 has a rubber hose from the vacuum advance to just before the metal clip on the intake manifold. At that point the line is chrome and then swithes back again just before attaching to the carb. Sounds like L79's had the chrome section and the 300 HP cars had a steel section.
                Gary
                • Ronnie Robertson # 36786
                  Re: L79; Vacuum Advance line
                  My '66 300Hp has a plain steel line connected at each end with rubber tubing. It also uses the painted clip to hold the line in place.
                  ROnnie
