Loosen up, correct restoration of your vettes.... - NCRS Discussion Boards
  • George Daina
    Boy, it really galls my threads when these ignoramuses go off about how the Corvette crowd is 'over-restoring' cars! I say, restored means *exactly* as the factory did it, no matter what. I spent 95 weeks last year doing an accurate and complete ground-up restoration on my '67. And, let me tell you, some of those rubber and glass pieces are *really* hard to restore after grinding them up! Thankfully, the metal pieces are easy to remelt and form.
    For some folks, simply applying a bit of overspray while painting is 'good enough.' I scoff at this. I meticulously copied onto the mufflers, droplet by droplet, the exact overspray pattern that was there originally. Even the runs and sags at the bottom of the door panels were duplicated. Your average 'restorer' will just slap some new paint on, calling it 'original' if it is the same color. Jeeez. I chemically removed every vestige of *the original paint*, then broke it down, reformulated it, and re-applied it. Sure, I had to use substitute volatile carrier (thinner), but since it evaporates anyway, I claim that it was not originally 'on the car' when it left the factory gates.
    Some folks think using the 'correct' fasteners is good enough. Ha! I made sure to cross-thread the left rear upper transmission crossmember bolt, just as the (sometimes inebriated) factory worker was known to. I removed the third from the right lower grille attachment screw, which a previous owner had erroneously installed, in spite of the well-documented fact that none of these were installed at the factory until after 3:43 pm on October 17th, 1966. I made sure to scratch the frame in the appropriate places, just as the handling mechanisms
    at the factory did. Some previous owner had removed the scratches, in an effort to make the car 'perfect.' What was he thinking? I even installed the #3 cylinder's exhaust lifter upside down, which was a rare (1 of 3 such built), but documented occurrence. Sure, it runs like hell, but hey, it's _original_!
    Some folks get a new set of tires that LOOK like the originals, and call that good enough. Not me. I got THE ORIGINAL tires out of a landfill, ground them up, and restored them. I was able to find about 91.7% of the rubber which had worn off, by vacuuming the roadside dust over the roads the car had travelled, and separating out the correct molecules from the other debris with a double diathermic isopropa diaphanometer molecular identifier. NOT cheap, le me tell you. But, correct is correct. Some folks put on new valve stems and caps, and away they go. We purists know that it IS important to align the seam line on the valve cap to the correct angle, just as it left the factory ('indexed' valve caps).
    Changing the oil is considered routine by some 'restorers'. They throw out the old, slap in some new, maybe even 'improved' oil, and a new filter. Not a real purist. I have the original oil broken down and re-refined. The old additives are removed, restructured, and re-added. I even recover as many molecules of the burned or dripped oil as possible, and add them back in. Of course, the filter must be dismantled, which ruins the case, so it has to be remelted and reformed into a filter. Re-using the original paint, of course.
    Some bozos throw in a Sears Die-Hard, and off they go. Some so-called restorers buy a reproduction 'tar-top' battery, and call THAT good enough (*scoff*). I found my original battery and remanufactured it. No wimpy replacing the innards with new, either. I melted down the original plates, then recast them in the correct factory molds. Saving the original electrolyte, of course. Now, you might think, gee, that seems pretty far-fetched, this guy is extreme. Well, you ain't seen nothing yet. I also was able to procure the original electrons which had come with the car, and reinstall them. It seems that over the years, the car had given and recieved a few jump starts, and some of the original electrons had thus transferred to other vehicles, and some from other cars had contaminated my car. Thankfully, there is an electron sorting and ID accessory for the molecular identifier, which allowed me to correct this blatant slap to _true_ originality.
    One thing holds me back from being 100% correct. Some fool of a previous owner had changed the tires, and did not retain the original air. I know, hard to believe, but it happened- some folks just don't 'get it.' Now, I have located about 24.6% of the original air molecules with the double diathermic isopropa diaphanometer, but many of them have been sucked into other engines, combusted, and turned into CO, CO2, NOx, etc. If anyone is aware of a device to spot the correct air molecules after they have been broken up and combined in other chemicals, please let me know. I guess I COULD settle for some air molecules from the Bowling Green tire-mounting area vicinity, captured about 9:47 am on September 5th, 1966. Ah, well, it's only a few points off at showtime...
    As soon as I'm done, and win a few trophies, I plan to sell it. I have invested $45,000 in parts, and $45,000,000 in labor, and expect to sell it for about $37,000. If any one wants to buy it, please hurry, it won't last long.
    Hope ya all had a Merry hristmas, and have a safe and Happy New Year
  • robert nissenbaum
    Re: Loosen up, correct restoration of your vettes.
    And I thought a correct restoration was to merely return the car to stock as it came from the factory using original parts where possible and accurate replacements as needed in an effort to accurately reproduce what GM created in an attempt to preserve the beauty and history of the Corvette.
    No wonder youngsters aren't joining NCRS.
    Good thing the restoration of old homes doesn't require numbers matching parts, paint and wallpaper made from the same materials, and old style windows, plumbing and heating units, and wiring and construction in the exact method they were originally built. None could ever be lived in as they would not up to current local building codes and no one could possibly use a home restored in this manner. It would merely be display house. Personally, after spending that kind of money, I want to live and party in it.
    • John M.
      • January 1, 1999
      • 1553
      Georgie,
      Don't hold back now, tell us what you really think!
      Regards, John McGraw
      • Tom Merkel
        Nice job, Georgie boy.
        Geez...and I thought I was the only one with documented "original air" in my C2.
        tm
        • Bernard M.
          • August 31, 1994
          • 341
          You call yourself a "restorer"? You should be ashamed! How can you even consider Bowling Green air in tires that were mounted in St. Louis?
          • George Daina
            Shame on me.....I know......
            I didn't catch it till I posted it....then couldn't go back and correct it...
            Anyway the accolades belong to a dude on "The Other Forum"...hehehehe...I just cut and pasted, thought ya all could use a good laugh.
            • Bob Babcock
              Gee George, someone posted a verrrrrry similar story about a year ago. You either have a sole mate or this is your annual holiday message, hee hee. I enjoyed it (again?).
              Just in case I am wrong about the above, I wonder how handled the soft top tag that obviously disintegrated over the past 35 years or so....and don't tell me a stud muffin like George Daina drives a coupe. Resurrecting the tag must have been a chore.
              Merry Christmas George
              • George Daina
                What me drive a coupe?
                NEVAH!!!!!! Gotta have that wind ripping through my hair when motoring down that long blue highway. Nothing like wind and hair blowing all over your head...and the sound of the side pipes....heaven on earth......
                Regarding the soft tag....there is a machine that unpulvorizes the molecules, much the same way the Ghost Busters pulverized the naughty and mean ghosts.
                Have a safe New Years, if you drink just one drink, call a cab
                • Chas Kingston
                  • Paul L.
                    • November 1, 2002
                    • 1414
                    George,
                    You may have put the cat amongst the pigeons! But I tend to agree with you. My 1979 is "stock" but not "original." And as I learn more about NCRS as a newbee those two words take on more significance. I have been very careful to keep the car stock and to use GM "service" parts when available. And I thank Joe L. for giving me very solid advice in that regard. But they are not in many instances.
                    So I will go aftermarket. I will be darned if I will pay three times or more the price if I can find a good, functional substitute for a GM part. As an example my alternator was originally 37 amp. That was not enough output. So I went for a 71 amp two years and exchanged the core. So now the unit does not have the correct numbers on it. But it IS a direct substitute. And I have no intention of searching the internet for a right numbers core and rebuilding it to a higher amperage.
                    Back to those words stock and original. I am learning. But I will stay with "stock."
                    • Tom B.
                      • February 1, 1994
                      • 779
                      • Ray C.
                        • June 30, 2001
                        • 1132
                        Hi!
                        Some of us are even crazy enough to restore early homes to the original condition (very hard to hide the electric). I moved a C.1825 home six miles and the building inspector called it a mobile home. The people that make up the NCRS Tech Board help to make Corvette restoration an enjoyable experence.
                        Thanks to all that have helped in my restoration project!!
                        Ray
                        Ray Carney
                        1961 Sateen Silver 270-HP
                        1961 Fawn Beige 315-HP
                        • Ed Driscoll
                          Whew,
                          I smell a book deal..
                          • Michael Jones
                            George, you made my day! Thanks! *NM*
                            • Lane Ockerman
                              Tom,
                              A great Beatles tune made better !!!!!
                              Lane #38102
