New Photo Size Limitation ?? - NCRS Discussion Boards
  • John S.
    • June 15, 2015
    • 505
    Took me a while to get signed into the new TDB but I’m in. My first post was going to be a reply with photos but both photos I tried to attached said they exceeded the 2MB size limit. I have posted many photos to the previous TDB without having this issue. Any chance of getting this changed ?? It can be very difficult to post or answer a topic without the ability to show photos. Photos were taken with the same device and procedure as previous, please advise.
    1973 L82 M21 4 Speed, very original and well documented driver/survivor
    NW Chapter Member, 2016 Bend Regional Top Flight
    73/74 TIM&JG 3rd Edition Revision Team Member
  • Gary C.
    Administrator
    • October 1, 1982
    • 17722
    John,
    What size is the photo you're trying to post and what is the resolution - pixel width and heighth?
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • John S.
      • June 15, 2015
      • 505
      Gary, photos that would not post
      4.3 MB 3073x2066
      4.2 MB 3235x2008
      Photos recently posted in December with no problem prior to TDB upgrade
      4.4 MB 2815x3527
      2.4 MB 3000x3343
      3.6 MB 3833x2735
      3.3 MB 3693x2821
      All shot on same Samsung S23 with 12MP resolution
      Hope this helps, please advise.
      John
      • Gary C.
        Administrator
        • October 1, 1982
        • 17722
        John,
        Try uploading 1 of the photos and let me know.
        Gary
        NCRS Texas Chapter
        • John S.
          • June 15, 2015
          • 505
          Okay, just tried to post photo as an attachment to this reply and received this error message
          File exceeds PHP’s file-size limit of 2.00 MB
          Photo would not post.
          I do see a new option of Upload or Select from Photo Album. The Album contains all of the photos I previously posted back before the update. The photo I tried to post here was done with the Upload function.
          Similar issue noted by Keith M. in his post titled 69 Soft top pin.
          • Gary C.
            Administrator
            • October 1, 1982
            • 17722
            John,
            Sorry, appears there's a new file size limit of 2 mb we're going to have to follow.
            Gary
            NCRS Texas Chapter
            • John S.
              • June 15, 2015
              • 505
              Okay, but from a user perspective this seems like a step backward.
              • Gary C.
                Administrator
                • October 1, 1982
                • 17722
                John,
                In most cases the human eye can't tell the difference between 1 mb and 4 mb photo.
                Difference would show only in high resolution printing.
                On a side note, NCRS is running out of server disk space, so photo size reduction will help with that.
                Gary
                NCRS Texas Chapter
                • John W.
                  Administrator
                  • November 1, 1974
                  • 5089
                  I found this setting and changed it in MultiPHP INI Editor
                  Lets see how that works.
                  Administrator
                  www.ncrs.org
                  • John W.
                    Administrator
                    • November 1, 1974
                    • 5089
                    This image was 6.1 MG and when uploaded it was reduced to 1.37 MG 800x600 pixels in size. I changed the upload_max_filesize to 8MG. We will see how that works.
                    Remember that newer cameras and phones can take 10 MG images. You may have to resize them still before you can upload them.
                    Administrator
                    www.ncrs.org
                    • John S.
                      • June 15, 2015
                      • 505
                      John, thanks for the reply and making the update to allow 4mb photos. I think the biggest challenge going forward will be the minimum resolution of newer digital cameras. We have 3 at home and their minimum resolutions are 8, 12 and 16 MP. Time will tell.
                      • John W.
                        Administrator
                        • November 1, 1974
                        • 5089
                        John,
                        I use Photoshop so it is relatively easy for me to reduce the size of pictures.
                        You posted these file sizes:
                        4.4 MB 2815x3527
                        2.4 MB 3000x3343
                        3.6 MB 3833x2735
                        3.3 MB 3693x2821
                        The largest pixel size you show is 3833 px. That is 53.236 inches wide. Great if you want to print a billboard, but on the webpage 800 px is as large as you want to go. Otherwise people have to scroll left and right and up and down to see the entire picture. The picture I posted above it 800 px wide.
                        When you reduce the pixels you reduce the size of the file as well.
                        To reduce a photo's file size on Windows, you can use the Photos app, Microsoft Paint, or Microsoft Picture Manager:
                        • Microsoft Paint
                          • Right click on the photo and select Open with
                          • Select Paint
                          • Click the Resize option or press Ctrl and W
                        • Microsoft Picture Manager
                          • Select the photo you want to compress
                          • Click the Picture Tools Format tab
                          • Click Compress Pictures - Compress won't necessarily reduce the file size that much
                        • Photos app
                          1. Open Windows Explorer and navigate to the photo folder
                          2. Right click on the photo and select Open with
                          3. Select Photos
                          4. Click the three dots menu and select Resize
                          5. Use the quality slider to reduce the photo size
                        To reduce an image file size on a Mac, you can use the Preview app or an online tool:
                        • Use the Preview app
                          1. Open the image in Preview
                          2. Select Tools > Adjust Size
                          3. Select Resample image
                          4. Enter a smaller value in the Resolution field
                        • Use an online tool
                          • Choose a desired aspect ratio and compress to any size
                          • Download the resized image
                          1. Upload the image to an online tool like Adobe Express or Shrink.media
                        You can also compress a file on a Mac by:
                        • Navigating to the file in Finder
                        • Control-clicking on it and choosing Compress
                        • Waiting for the file to be compressed
                        JPGs are a good choice for storing and sharing images because they maintain reasonable image quality at a relatively small size.
                        Administrator
                        www.ncrs.org
