C1 tie rod end grease boot - NCRS Discussion Boards
  • Thomas H.
    • August 31, 2005
    • 1068
    I was able to get some time today to clean the grease off of one of the tie rods from the 60. The outer tie rod has a metal grease cover is this right, I always thought they were rubber. The inner has the rubber cover. Both ends have blue inspection paint on them. Was this the way they came?
    Tom
    2007 Z06, Lemans Blue
  • Thomas H.
    • August 31, 2005
    • 1068
    Re: C1 tie rod end grease boot
    I will clean the other side off tonight and see if it has the same set up.
    Was this a factory tie rod end, metal vs rubber boot?
    Tom
