62 brake line hose - NCRS Discussion Boards
62 brake line hose
  • John F.
    • March 23, 2008
    • 2415
    62 brake line hose
    Is there any kind of a valve in the rubber brake line. I am rebuilding the original wheel cylinders and thought about using the hoses. One appears very clear when I flushed with alcohol.
    John
  • Bob H.
    • July 31, 2000
    • 821
    Re: 62 brake line hose
    No valve I'm aware of. When rebuilding the brakes on my 62, I thought about reusing the lines but decided against it. If one blows, there is no backup with the single resevoir. I would only do it if is was a trailered queen.
      John
      John -
      The only valve in a brake hose is the check valve that forms when the inside of the line deteriorates and swells due to age. Don't even THINK about using brake hoses more than ten years old - replace them - they're cheap.
      • John F.
        • March 23, 2008
        • 2415
        Thanks. I will replace all. To keep the car correct, what is the best supplier? Corvette Central?
        • Daniel K.
          • April 1, 2002
          • 190
          John,
          Good idea to replace all the lines. One pin hole = no brakes........
          I used CC for most all the parts I needed to replace on my 62.
          Dan
          PS
          Looks like you are having a ton of fun with your new car.
