Original 67 Door Panel Restoration - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    I'm looking for someone who can restore a couple of of original 67 door panels. I DO NOT want to recover them. I need an excellent interior vinyl person who can fix a couple of bubbles and repair a few tears along the back edge of the arm rests. The panels are really in pretty good shape. Anyone have any suggestions? Thanks.
    Kirk
    Re: Original 67 Door Panel Restoration
    Let your fingers do the walking through the Yellow Pages...
    Where I've seen good results from repair of vinyl is from those who specialize in that doing restaurant seating, Etc. If they're good, and the rips/tears aren't too bad to start with, virtually invisible repairs can be achieved.
    BUT, heads up, if the original vinyl has dried out to the point that it has cracked/ripped, the remaining fabric may not be that far behind the damaged area(s) in terms of ultimate wear...
    • Bill W.
      • November 1, 1977
      • 402
      Kirk
      Kirk,
      I have used a company called "Color Glo" with good success for the repairs you mention. If you don't find them in the big yellow book call the service department of some of the auto dealers. Bill
      • Tom M.
        • August 31, 2000
        • 231
        Kirk,
        Contact the local used car dealerships in your area, and ask whom the use. There is usually the "one" guy in most areas.
        • Scott S.
          • September 11, 2009
          • 1961
          Kirk
          Hi Kirk,
          I'm thinking about trying to restore my original door panels too, or at least exploring the possibilities. Did you try any of the ideas mentioned above, and if so, how did they turn out?
          • Chris E.
            • November 3, 2006
            • 1331
            I had an original set of 67 door panels repaired by a local shop. They had a "vinyl guy" that came in once a week for special jobs. He did a GREAT JOB.
            At the rear edge, at the top, the vinyl was completely warn away. Also, on the driver's side, there was a 2" long tear from the bottom of the door handle latch opening going straight down. They couldn't do anything about the bubble without completely taking the vinyl off.
            Can you see the repair?
            These panels only took a 1 point deduct in Regional judging this May in Iowa.
            A big thanks to Daryl and his crew at Precision Upholstery.
            150 West 60th Street
            Minneapolis, MN 55419-2316
            Get Directions
            (612) 861-4637
            Chris Enstrom
            2011 Z06, red/red
            • Scott S.
              • 1961
              Get Directions
              (612) 861-4637
              It looks like they did a really nice job on your door panels, that's very encouraging. Definitely worth looking into further.
              Thanks!
              • Henry S.
                • April 30, 2005
                • 816
                Get Directions
                (612) 861-4637
                Chris, EXCELLENT JOB!!
                Kirk, I agree with some of the other guys. Check with your local dealerships that have been in business for awhile and use the same guy. We have a guy here in Decatur, Dr Vinyl. I took my 67 to my brother-in-laws shop and met the guy there to repair my door panels. Waited while he did the work and I was SUPER happy with the results. Like Chris' it's tough to see where he repaired it.
                • William H.
                  • January 11, 2010
                  • 65
                  Just dashes does this kind of work. There work is very nice but $$$
                  www.justdashes.com
                  • Peter J.
                    • September 30, 1994
                    • 586
                    Tom's idea is right on target. When I was in high school I worked as a lot boy at my brother in laws Ford dealership and there was "one guy" who would come around once a week and fix the interiors on the new and used cars on the lot (there were over 200 used cars) and this guy was good, so good he had all the dealerships and used car lots in the lower end of the county.
                    • Chris E.
                      • November 3, 2006
                      • 1331
                      Thanks guys. I was looking for a picture of the door panels PRIOR to the fix, but I didn't have one. If you get RIGHT up close to it you can see the repair, but you have to know where to look, and be in direct sunlight.
                      I'm happy.
                      Chris Enstrom
                      2011 Z06, red/red
                      • Kirk M.
                        • June 30, 2006
                        • 1036
                        I found no one locally. I tried all of your suggestions and no one would touch the panels with a ten foot pole. Very frustrating. None of my crappy ideas worked either. Right now the panels are just sitting in their box.
                        Kirk
                        • Kirk M.
                          • June 30, 2006
                          • 1036
                          Originally posted by Bill Wilhelm (1600)
                          Kirk,
                          Is this local to Columbus, OH?
                          Kirk
                          • Peter J.
                            • 586
                            Kirk,
                            I didn't check to see where you lived, but somebody out there is fixing interiors for the dealerships. Call a couple of those some small independent used car lots and maybe you will get a referral to somebody who isn't afraid to work on one of "those Corvette Guy's" car.
