C2 Speedo Parts availability - NCRS Discussion Boards
    As usual, the 2nd worm gear (AKA diagonal gear) has worn where it interacts with the magnet / first worm shaft. Result is no odometer or trip meter movement.
    Seems to me that decades ago, you could buy just the gear. Is this still the case, and if so, any suggestons where I look ?
    • 43279
    Re: C2 Speedo Parts availability
    Wayne------
    Replacement automotive gears for odometers and speedometers
    • Ken A.
      • July 31, 1986
      • 929
      You do not want to use plastic gears in a C-2 speedometer. Email me your address & I'll send you the correct gear.
      • John S.
        • May 4, 2008
        • 427
        Any body else have the same problem? I have mine apart and it is identical to the picture. Need a replacement.
        John Seeley
        67 Black/Teal 300 hp 3 speed coupe
        John Seeley
        67 Black/Teal
        65 Maroon/Black
        35k mile Fuelie coupe
