1972 small block 3991399 to 330813 water pump changeover - NCRS Discussion Boards
    • 11643
    Do any of you with April / May / June / July 1972 Corvette small blocks (L-48 or LT-1) know if your car still has the original water pump? If so, would you mind checking the pump casting number? Date on the pump would be interesting if you can read it, but casting number is the primary part of data I'd like to know. I've already narrowed down the casting date changeover to about April 1st, 1972.
    I'm trying to "pin down" the changeover from the 3991399 pump to the 330813 pump. The 330813 pump used in late 72 does not have the large boss on the top tapped and plugged. It has a smaller, non-tapped boss. So, if you have a pump with the large tapped boss (see upper picture below) then it's not correct and I don't need to know anything about it. The water pump in the bottom picture below is a 3991399 on an early 72.
    The Judging Guide lists both 20 000 and 22 000 as possible serial number changeover points depending which paragraph you read. I'd like to see if it's a range, and if so then correct the next edition of the JG.
  • Henry A.
    • May 31, 1990
    • 103
    Re: 1972 small block 3991399 to 330813 water pump changeover
    The bottom pic looks like it is of my 72....am I correct?
    Henry Atsma
    54 White/Red
    63 Red/Black SWC
    67 Elkhart Blue/Black BB Roadster
    91 Black/Red ZR1
    96 CE - LT4
    07 Red/Tan
      • 11643
      Yup.
      I knew the pics was in my collection and easy to pull up.
      • Harmon C.
        • 3228
        I would be interested in the data but mostly the use of the plug in the first picture. As a 73 judge I'm looking for a pipe plug with a square head and would like to know if the one in your picture could be correct for an early 73 built car built in Sept. 72 or if it was ever correct for any Corvette.
        Lyle
        • Don L.
          • August 31, 2005
          • 1005
          Originally posted by Lyle Chamberlain (24961)
          Lyle, by "square plug", do you mean the one in the attached pic? I recently removed this pump and replaced it with the correct 399 casting.
          Don Lowe
          NCRS #44382
          Carolinas Chapter
            • 11643
            Don,
            Casting number and date on your former pump?
            I'll admit that I have no idea what the casting # and date are on my 72 as shown in the first pic. Maybe I should check.
              • 6942
              Patrick, My Apr Late 72 Corvette Has The Water Pump Without The Boss The Date On Pump If Im Reading Correctly Looks To Be C22, The Part No Must Be Under The Pulley I Cannot Seem To See It Even With The Mirror On The Bottom.(ser. No Is 519388)
              • Don L.
                • August 31, 2005
                • 1005
                Don,
                Dunno, but will climb up in the attic and retreive/check/advise later this afternoon.
                I'm rained in today, and plan to tinker on the car. Hmmm. One thing I'll do is re-tape my vacuum harness - know what I mean?
                Don Lowe
                NCRS #44382
                Carolinas Chapter
                  • 11643
                  Ed,
                  I'd pay to to check that casting number.
                  However, my bet is that it will be a 3991399 based on the casting date. I own a C 8 2 that is a 3991399.
                  If you can check at some point I'd be grateful.
                    • 11643
                    LOL!
                    No rain here "yet" though it looks like it could hit at any moment.
                      • 6942
                      Pat, Ill Check Later Today And Let You Know.
                      • Don L.
                        • August 31, 2005
                        • 1005
                        Me too thinks the C22 is a 3991399. Mine is a C 23 1.
                        When researching the numbers for my project, Bill Mock advised me that these pumps were made in batches, and for my August 11, 1971 built engine, the closest he'd ever seen was the March 1971 batch. It fit my date window (barely), so I took it.
                        Patrick/Lyle, my "former pump" as shown in my earlier pic is GM 330813. How 'bout that? Looks like the date is H 25 2. What is this?
                        Don Lowe
                        NCRS #44382
                        Carolinas Chapter
                          • 6942
                          Pat. Casting Date Is C82 And Part No. Is 3991399. I Got A Better Look W/ The Pulleys Out Of The Way.
                            • 11643
                            Me too thinks the C22 is a 3991399. Mine is a C23.
                            When researching the numbers for my project, Bill Mock adivsed me that these pumps were made in batches, and for my August 11, 1971 built engine, the closest he'd ever seen was the March 1971 batch. It fit my date window (barely), so I took it.
                            Don,
                            C 2 3 doesn't make sense. Mar 2 1973?!? Not if they stopped making them 1 year earlier... Maybe a C 23 1?
                            Most parts are batch built. FYI my June 71 (71 MY car) had an August of 70 (!) 3991399 on it.
                            I would suggest that your other pump is for an early 1973 motor. It may have some value to a 1973 owner.
                            • Don L.
                              • August 31, 2005
                              • 1005
                              Don,
                              I "typoed". Typing too fast causes errors, eh? See edit - I fixed it to read C 23 1. Indeed that's what it is.
                              I plan to take it to Carlisle, hoping someone can use it. First need to know that it's not just a "general" pump...
                              Now. Back to the vacuum taping...
                              Don Lowe
                              NCRS #44382
                              Carolinas Chapter
