1972 small block 3991399 to 330813 water pump changeover - NCRS Discussion Boards
    • 15637
    Re: 1972 small block 3991399 to 330813 water pump changeover
    Patrick,
    Since the water pump was installed on engine assembly at Flint, I suggest you would be better served tracking the water pump casting date against the engine assembly date. That would eleminate the time lag for pulling the engine from stock at St. Louis.
      • 11697
      Patrick,
      Actually what I'm looking for is ANY 72 with a 330813 casting. Once I know that, I'll also check closer. In the meantime I'll ask Ed since he's the only one close - other than my car, which won't help.
      Patrick
        • 11697
        #18
        Pat. Casting Date Is C82 And Part No. Is 3991399. I Got A Better Look W/ The Pulleys Out Of The Way.
        Thanks Ed!
        Any chance you know your engine assembly date, as Terry notes below?
          • 6958
          #19
          Pat, The Casting Date On Rear Of Engine Block Is C17
          • Harmon C.
            • August 31, 1994
            • 3228
            #20
            Originally posted by Don Lowe (44382)
            Lyle, by "square plug", do you mean the one in the attached pic? I recently removed this pump and replaced it with the correct 399 casting.
            Yes that is the plug and also the boss it screws into looks different than Patricks picture.
            Lyle
              • 11697
              #21
              Ed,
              And the assembly date and code on the stamp pad?
                • 6958
                #22
                Pat, The Engine Block Stamp Pad Numbers Are Vo406ckx-12s519388, The Cars Body Build Date Is I21- April 21 Is This What You Needed?
                  • 15637
                  #23
                  Ed,
                  Patrick:
                  By Ed Johnson, halfway up your thread, in response to one of Lyle's posts:
                  "Pat, The Engine Block Stamp Pad Numbers Are Vo406ckx-12s519388, The Cars Body Build Date Is I21- April 21 Is This What You Needed?"
                    • 11697
                    #24
                    Patrick:
                    Yes, I saw that. He responded to me but it ended up in the wrong "thread position."
                    Note the time of the two posts.
                    Now if we could just hear from cars after 19388 it sure would be nice.
                      • 43285
                      #25
                      Originally posted by Lyle Chamberlain (24961)
                      Patrick
                      I would be interested in the data but mostly the use of the plug in the first picture. As a 73 judge I'm looking for a pipe plug with a square head and would like to know if the one in your picture could be correct for an early 73 built car built in Sept. 72 or if it was ever correct for any Corvette.
                      Lyle-----
                      I don't think the internal hex head plug was ever used in PRODUCTION on any 72-82 Corvette. I think that all were the external square head. VERY "funky" looking, but I believe that's how it was.
                        • 6958
                        #26
                        PAT, I DONT KNOW IF MY POST MADE IT YESTERDAY BUT THE STAMP PAD ON ENGINE READS- V0406CKX 12S519388 (BODY BUILD DATE I21)apr21
                          • 11697
                          #27
                          Ed,
                          Yes, it's here.
                          Thanks!
                            • 11697
                            #28
                            OK, so car 19388 has a 3991399 dated C 8 2 on an engine assembled April 6th, and car 24796 has a 330813 dated D 18 2 on an engine assembled May 31st.
                            I know that there are other late 72 small blocks out there - any info?
                            • Jerome P.
                              • October 22, 2006
                              • 607
                              #29
                              Pat, you asked about the numbers on my water pump.
                              My car is 23822 and has a 3991399 water pump dated C82. on an egine assembled April 21.
                              I wish I would of taken some pictures, but you need a camera and you know what? I left it home. If you need a picture I will try to remember the next time I go up to the garage.
                              I would be interested in your conclusion(s) when your done.
                              Let me know.
                              Jerry
                                • 11697
                                #30
                                Let me know.
                                Jerry
                                Thanks.
                                That tells me that 1) the date I just bought - same as yours - would be correct for my car, 22917, and that 2) the 3991399 was used later than the JG currently lists. As Terry noted, we will have to compare engine assembly dates to water pumps.
                                If anyone else has an April or later 1972 small block, please check your water pump for me.
                                Patrick
