Any good photos of an original 69 L46 Engine bay? - NCRS Discussion Boards
  • John M.
    • November 10, 2008
    • 364
    I was looking for some photos of a correctly detailed or original 1969 L46 engine bay.
    Primarily looking for photos of rear firewall area to verify vacuum hose and wire routing / dressing.
  • John M.
    • November 10, 2008
    • 364
    Re: Any good photos of an original 69 L46 Engine bay?
    Bump.
    Even 70 L46 or LT-1? Looking for detail on vacuum hose routing And wire dressing on firewall area.
    I'm not even close at this point. I know some route behind Washer pump, others do not, dressing and routing etc.
      • 15631
      If you will settle for 1970 LT1. I have posted some of these before,a nd the site software will not allow me to post the same photo a second time.
      See here (search is your friend): https://www.forums.ncrs.org/showthre...69021&uid=7770
      • John M.
        • November 10, 2008
        • 364
        Thanks Terry, I've been searching my Hiney off.
        • Erik S.
          • 407
          John - I consider my 69 L46 as fairly original (although I have never assessed it in great detail as I purchased the car only a year ago and mainly drove the heck out of it the first year). I will make photographs this weekend of the firewall area - any specific area's you would like to study?
          Erik
            • 11692
            My only caveat is that in researching cars with respect to my own 71, I found that there were differences in layout as the model year went along. I would not do more than "generalize" if you're using a 1970 like Terry's even if his is an early car. I looked at 71's for a few years, taking pictures of each, to give me enough info to restore my 71's engine compartment back in 1996.
            Keep looking for 69s. Check ebay and Google images, too.
            • John M.
              • November 10, 2008
              • 364
              I have a very late 69 (18th prior to end)
              I'm specifically looking for Vaccum Hose and wire dressing on the firewall in these 2 specific areas.
              1. Which Vacuum hoses route behind wiper motor, which do not
              and proper looping and or dressing of the rest?
              2. How is the wiring dressed and routed in relation to the vacuum hoses?
              Mostly the vacuum wiring question. In haste I routed them all infront of the wiper motor and see from the AIM that some are wired behind.
              This was obviously done is stages so certain hoses attached first, before or after wiring and before or after washer lines etc.
              I can get close and research some correct cars when I get done and get her in the grass but I need to nail down question number (1) as there's labor involved with that one.
              • E S.
                • December 29, 2008
                • 451
                Have not taken any pictures lately,but I do have a '69 350/350 which is a low mileage,untouched original,fairly late ser. #(307xx),that I ordered in Feb. '69. (car was gold certified at Bloomington in the 80's) Car should be a definitive example for you, but who knows? Strange things were happening that year,what with the strike,and all- I tried to order an LT-1,as they were supposed to be available,but that did'nt happen, and my order was canceled,and I had to start all over again, and did'nt receive the car until the last of Oct!
                If you have'nt found the info. yet, I would be glad to take and post pictures of the firewall area for you.
                EJ
                • John M.
                  • November 10, 2008
                  • 364
                  Mr. Storrer, that would be outstanding. Several engine bay shots would be very much appreciated. (vacuum hose routing from several angles on the firewall without the air cleaner on especially) and as many different shots and details you can take.
                  E-mail would be great, not only would I like to see it for the correct detail, I'd love to see the car and hear the story behind a one owner example of a 69 L46. (so toss in a couple Glamour shots)
                  johnlord@zoomtown.com
                  Those original, one owner, untouched cars are worth their weight in Gold as examples to us restorers.
                  I'll make you a deal, if you e-mail them, I'll post them as I know there's a few L46 guys on here that would love to see them.
                  Thanks a heap!
                  • Steven H.
                    • June 29, 2009
                    • 137
                    Nice! I can use all this as well.
                    Thanks for the heads up John
                    • Kenny C.
                      • March 2, 2009
                      • 191
                      Me too I would love to see them and could dearly use the info as well. If you are e-mailing them out my address is KenC100@aol.com if you wouldnt mind adding me to the list. Best Regards
                      Kenny
                      • John M.
                        • November 10, 2008
                        • 364
                        Told ya there were a few L46 guys that would love to see them.
                        • Erik S.
                          • 407
                          Ok - here we go: comments are appreciated for me to learn where stuff is not correct or typical. This is my L46 convertible # 19211 (H15 build date).
                          • Kenny C.
                            • March 2, 2009
                            • 191
                            Erik
                            Great pictures Thank you very much it really helps. If I could continue to trouble you how about some shots of the rest of the engine bay and the routing of lines along the drivers side fender and up to the front end.
                            Regards
                            Kenny
                            • John M.
                              • November 10, 2008
                              • 364
                              That helps me a bunch. Several observations out of that. Much more liberal with the Tie Wraps than I thought, filiment tape on the small air valve, lots of good stuff.
                              They must have moved the Window actuator relay to the driver side firewall very late in the year then.
                              Also interesting that there's virtually no overspray on the Bellhousing.
                              Thanks again, this is nice to see.
                              Is this example virtualy untouched? What is it's history?
