coil springs - 1972 small block - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    What finish/color are the front coil springs on a 72 small block car. Mine have some minor rust, etc on them and would like to clean them up to as near original as possible. Does any one have a pictue or pictures they could share?
    Jerry
    • 11644
    Re: coil springs - 1972 small block
    Michael Hanson used to post some pics of the Corvette line which showed this. To approximate the finish, have the springs shot blasted (not bead or sand) and then spray with CRC 350 or 400, or cosmolene, or similar. You'll then have the correct finish.
    • Jerome P.
      • October 22, 2006
      • 607
      Thanks Pat.
      What is CRC 350 or 400?
      Jerry
        • 11644
        Originally posted by Jerome Pederson (46381)
        Thanks Pat.
        Jerry
        Corrosion inhibitor made by CRC Industries.
        Higher numbers = "longer" protection
        • Franz E.
          • March 1, 1997
          • 96
          Jerry
          • Gary B.
            • 7024
            Coil springs - dipping in WD-40
            Originally posted by Franz Estereicher (28907)
            .... Experiment: take a piece of bar stock, sand blast with very course grit medium to mimic shot peening, afterwards dip into WD-40 or new engine oil and allow to dry.
            All of us with springs to prep should on one day and have a dipping party since it should take about 5 gallons of WD-40 to do be able to complete the dip process.
            Gary
              • 11644
              I don't think that WD-40 is thick enough nor would last long enough. The CRC products would work well - and just like WD-40 you can just spray it on.
