From time to time I've seen threads on "Frame Pull Date". I've often wondered the significance of this.
Why would GM go to the trouble of writing a date on a frame when they are going to use it immediately? (as in "take the next frame off the pile, Joe,
   and date it before you place it onto the chassis assy table"....)
If the frame is "in the assembly line system" then GM will already know when it started down the line, as they knew how long it took the assembly process to transpire.
Could that date be more significant as the date the frame was produced at the frame manufacturer, so that GM could find them in inventory if something like a "missed" weld were found in a batch of frames????
On later models (my 67 anyway) the date was stenciled along with the part number at the manufacturer.........OR Joe
  the date "stenciler", was very precise on the assy line.....
Comments?????
   and date it before you place it onto the chassis assy table"....)If the frame is "in the assembly line system" then GM will already know when it started down the line, as they knew how long it took the assembly process to transpire.
  the date "stenciler", was very precise on the assy line.....Comments?????
. Also, text under one of the pics says: "the date corresponds to a Friday, and the car was completed on the following Monday, April 12th" (I missed that too
