Visa dispute against D&M Restoration Clock Tachometer this will open your eyes - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    I sent my survivor clock and Tachometer to D&M Restorations. They were to clear over the original numbers dates and cadmium plating . I went over this several times with them. When I got them back they had taped over the ink stampings and then bead blasted the cans. . Then they spray painted the cans. When they pulled the tape off it pulled the number off. .They had the original plating around the numbers the rest was spray paint. Looked horrible .See pictures. The clock did not work and they used the same old cracked bushing around the terminals. They painted over the needle and inside of the cans right over the old peeling paint. The tachometer made noise and the bounced around. Charged me close to $700.00. I contacted them and they had no way to replate the cans or stamp the numbers and dates on. I then sent them to Ricks Restoration. Not the one on TV. He did a beautiful job. See pictures. They offered no help and when I confronted them on any issue Patrick was going to talk to the NEW owner and then did not respond Back.
    So I filed a claim with VISA. After many forms, Emails and telephone calls to supervisors the dispute was denied. VISA has a STRICK policy if you have any service work done and do not have a written estimate describing the work to be performed they will give NO help. Visa now has hired a third party company to handle disputes. I am sure there numbers are looking a lot better.
    double click the pictures
    Last edited by Gary C.; August 1, 2014, 02:13 PM. Reason: edit links requested by OP
  • Jerry B.
    • August 31, 1994
    • 416
    Re: Visa dispute against D&M Restoration Clock Tachometer this will open your eyes
    Hello Dan. You might check your photo references. "Apologies, but the page you requested could not be found. Perhaps searching will help" But of course if could be on my end. Jerry
    • Dan P.
      • December 1, 1990
      • 683
      you will have to copy and paste each picture in your browser . I hues i did not do the pictures right . Also look at http://danpatchappraisals.com/clock2.JPG
      • Gary F.
        • August 29, 2010
        • 248
        Getting a 404 ERROR on the pics. Just me???????
        • Jim D.
          • 2885
          Same here.
          • Guest
            Dan - sorry to hear you had a bad experience - don't remember you posting asking for recommendations, as I would have HIGHLY recommended Rick's Restoration as he is here in Maryland and does outstanding work. He is actually BIL of Brian Tilles and used to work for Brian before he moved to CA
            • Leif A.
              • August 31, 1997
              • 3658
              same, same...
              Leif
              • Michael J.
                • January 27, 2009
                • 7180
                Pictures look good to me
                • Jim D.
                  • 2885
                  Pictures now work for me. The workmanship shown is deplorable. Thanks for the heads-up.
                    • 3422
                    Hi Dan,
                    I'm sorry to read of your experience with D&M.
                    I was pleased with the work they did on my tach about 3 1/2 years ago.
                    I appreciate your post so that people are aware that the ownership has changed.
                    I'll stop recommending them.
                    I hope this situation can be resolved to your satisfaction.
