Re: C1 Clutch adjustment
Ok, one more check of your fork......Joe Lucia pointed this out in his post noted earlier.
Measure the vertical width of the main arm as it enters the bellhousing.
Measure the vertical width of the fork at the clevis end.
If the measurements are not roughly equal, and the measurement inside the BH is noticeably wider, you don't have the right fork.
