I'm once again at my witts end, (not a long trip on this project) as to how to get my clutch adjusted properly.
I have followed the instructions in the ST-12 and tried every possible way I can think of to make this work, but with no luck.
I first connect my pedal to zbar with the rod. The rod is 18" long with a slight curve to it in one spot. Looks original to me. Holding the clutch pedal up against the rubber stop, I then connect the clutch fork end of my clutch rod. The rod is 9 1/2" long and is straight.
I then push back on this rod to put the t/o bearing against the clutch.
Holding it in place I then attempt to put the swivel post on the rod into the other end of the zbar.
It isn't even close to the hole. Even by threading the swivel to the end of the threads on the rod it is not close enough to connect it.
I tried lowering the clutch pedal to the floor and that still does not allow me to attach the rod.
I even checked my t/o bearing to make sure I put it in correctly, which I did.
What else is there? I read thru all the posts on this that I could find and nothing is helping here.clutch linkage 001.jpg
How can it possible be this far off?
