Striker Plating - NCRS Discussion Boards
Striker Plating
  • Jim S.
    • March 1, 1986
    • 1401
    Striker Plating
    After spending an hour in the archives I have not come up with any hints on how to replate the Striker Assembly On my C-2. Can it be seperated and Reattached ? Taped off ?
    In other words how do I get the Shim and face all nice and Shiny without plating the center and still have the Riveted look when done ?
    I am hoping some of you guys have done this . Please speak slowly for I am "mechanically impaired" and or provide pictures whenever possible !!
    Thanks ,
    Jim
    • September 30, 1999
    • 710
    Re: Striker Plating
    Just take it off. If comes apart and the the plastic catch and spring ect out. Send out to be cad plated with other hardware. Make a note of what shim size is on each door it may be different. I'm not sure why you want the center different. It would have been plated the same.
      Director Region V
      • 1463
      Re: Striker Plating
      Hi Guys
      I believe the inner and outer striker pieces were zinc plated while the middle piece was natural die cast aluminum.
      HaND
      • Jim S.
        • March 1, 1986
        • 1401
        Re: Striker Plating
        Mike ,
        That is correct, and the reason for my question.
        Can the mechanism and the middle plate be disconected and put back together ?
        Jim
        • Greg T.
          • January 1, 2004
          • 136
          Re: Striker Plating
          The plater can mask that section.
          • Jim S.
            • March 1, 1986
            • 1401
            Re: Striker Plating
            Greg,
            I assume from your post picture you also restore antennas. If this is true please send me a PM.
            Thanks ,
            Jim
              • 710
              Re: Striker Plating
              I've always plated the whole striker. I never noticed that the plate was different.
              • Peter L.
                • October 23, 2007
                • 85
                Re: Striker Plating
                This thread was refered to me becasue I am having the same delimma about the strike plates on my 63. When I showed them to my plater, he said you couldnn't plate aluminum and steel together, and masking (which he doesn't do) might not even work.
                Can anyone who has done this as an assebly give me the name and contact info of their plater, so I can go to them with my striker assemblies? I really don't want to disassemble them.
