Cj-4 oil question - NCRS Discussion Boards
Cj-4 oil question
  • Steven S.
    • November 1, 1995
    • 151
    Cj-4 oil question
    I am running CJ4 15W40 in my 63 327. I also have a rebuilt 350 (new rebuild - broke in). Can I run same oil in it?
    • 15674
    Re: Cj-4 oil question
    That would require the oil to be in two different places at the same time.
    Though under Quantum Theory this is possible, the chances are extremely remote.
    • Steven S.
      • November 1, 1995
      • 151
      Ok, got a laugh out that - now, can I run the same brand/ type oil in a new rebuild with no problems?
      • Michael W.
        • April 1, 1997
        • 4290
        I'd say yes as long as you don't tell anybody on 'that other' forum.
          The would require the oil to be in two different places at the same time.
            Nothing like a little humor to start a Saturday morning off..
              • 1822
              Steven,
              What type of camshaft / lifters are you using in the 350? The type of valvetrain is what determines whether or not you should run CJ-4. Have you read Duke's famous engine oil article lately? I can post a link to it if you like. If you're using CJ-4 with a fresh build, I'd use a can of GM Engine Oil Supplement (E.O.S), too.
              • Steven S.
                • November 1, 1995
                • 151
                Stock cam and hydraulic lifters.
                  • 15674
                  I recommend CJ-4 in all vintage engines with sliding surface valve trains.
                  I take it you've never read the article Joe referred to, which has been published in The Corvette Restorer and a few chapter newsletters. It will answer any oil questions you have and blow up all the internet myths. Here it is - starts on page 3:
                  • Steven S.
                    • November 1, 1995
                    • 151
                    Thanks Duke, that is just what I needed to know.
                      • 15674
                      Do us both a favor and read the article.
                      • Steven S.
                        • November 1, 1995
                        • 151
                        I did so, thanks again.
                        • James S.
                          • July 31, 1990
                          • 126
                          The article below just appeared in the fourth quarter "Heart of Ohio Newsletter".
                          There appears to be a slight conflict of information between the effectiveness of CJ4 and CI4 grades of motor oil for vintage engines.
                          Is this more updated information or just a differance of opinion?
                          By Jeff Bernhardt
                          Jeff Bernhardt has provided a number of items below to help educate us gearheads driving these older cars relative to the kind of oil we should and should not be using:
                          What this stuff used to do was this: the zinc in the ZDDP would bond to the internal metal of our engines and form a protective "zinc plating" to prevent metal-to-metal wear.
                          5" H.G; the word got out that they were no longer being made and in short supply, and Corvette owners stockpiled their own garages with them. Try to find one now.
                          thinkzinc@motorheadoil.com
                          www.bradpennracing.com
                          The guys at World of Motor Works (www.worldofmotorworks.com
                          Jeff
                          (Article used with Permission of Jeff Bernhardt, owner of Restoration Station, Springboro, Ohio,
                          • Michael W.
                            • April 1, 1997
                            • 4290
                            "Sounds like Mr. Bernard has been reading 'that other' web site too much. Rotella CJ4 has ~1200 zinc, pretty much the perfect level for our engines.
                              • 15674
                              No, it's not a difference of opinion. It's a matter of one guy has facts and the other guy has his head up his a...
                              I can't believe anyone on this site would even consider that this guy has any credibility, nothwithstanding that he barely writes at the junior high level. "Stuff"? How about just calling it what it is - oil!
                              My sources of information included the API 1509 document that specifies the basic physical properties and tests to certify motor oil. It's on the Web and the link is in my article.
                              I doubt if this clown has ever heard of the API 1509 document.
                              Dowload it and read it for yourself.
                              I pity the poor slobs who have to endure this "newsletter", but then they probably believe every conspiricy theory that ever crossed their path.
                              It's just amazing some of the trash that gets printed.
