fuel pump - NCRS Discussion Boards
fuel pump
  • Paul W.
    • July 15, 2009
    • 21
    fuel pump
    Does Anyone Have A Picture Of A 1965 327 365 Hp Fuel Pump Top And Bottom
    Re: fuel pump
    Paul -
    Here are a couple that someone posted a while back, with the cast bottom.
    • Ray C.
      • June 30, 2001
      • 1132
      Re: fuel pump
      Hi! John
      Your picture of the fuel pump does not show a casting line in the area of the stamped number. I have seen some C-1 4657 pumps with and without the line. Could you please explain the casting line or the lack of?
      Thanks for any information
      Ray
      Ray Carney
      1961 Sateen Silver 270-HP
      1961 Fawn Beige 315-HP
        Re: fuel pump
        Originally posted by Ray Carney (36314)
        Hi! John
        Ray
        Ray -
        Maybe someone more familiar with the nuances of the 40083 pump can answer that - I haven't followed that detail.
        • Ray C.
          • June 30, 2001
          • 1132
          Re: fuel pump
          Thanks John, maybe someone will chime in!
          Ray
          Ray Carney
          • Vinnie P.
            Editor NCRS Restorer Magazine
            • May 31, 1990
            • 1573
            Re: fuel pump
            Article that will appear in the next issue of The Restorer by Joe Ciaravino has great info and photos...too large a file to upload here...if anyone wants a copy, email me directly...
            restorereditor@ncrs.org
            Identifying and Rebuilding the 6440083 Fuel Pump
            • Jim S.
              • March 1, 1986
              • 1408
              Re: fuel pump
              Ray
              Ray And Paul,
              I am not sure what you are looking for , but Here are pictures of the two 4003 I have if they can help .
              JIm
              • Ray C.
                • June 30, 2001
                • 1132
                Re: fuel pump
                You can see the line I am referring to in this photo of a 4656 pump.
                Ray
                Ray Carney
                • Jim S.
                  • March 1, 1986
                  • 1408
                  Re: fuel pump
                  Ray
                  Ray ,
                  If you look closely at the third picture of mine , the one on the right has that line albeit less pronounced the yours. The lower one on the left does not .
                  I am going to take a leap here and say it was probably the difference from a "first run" to a "last run" using that particular cast . They did wear out . In fact its probably also why some have sush a pristine AC logo on top and others are barely visable.
                  JIm
                    Re: fuel pump
                    Also the 40083 was cast of magnesium, so it has typically a darker finish than the typical pump, also note the two reinforcements between the tower and the circular surface covering the diaphragm
                    • Jim S.
                      • March 1, 1986
                      • 1408
                      Re: fuel pump
                      "also note the two reinforcements between the tower and the circular surface covering the diaphragm"
                      William,
                      Funny , but now that you bring that up , upon closer inspection (picture one ) One of mine has the reinforcements and one does not .
                      That is a much bigger difference than the cast line Ray pointed out .
                      Jim
                        Re: fuel pump
                        If it's missing the reinforcements, it's a "reproduction" to be kind, and not a very good one.
