1965 carpet underlayment wrinkles - NCRS Discussion Boards
  • Jimmy B.
    • July 31, 1980
    • 584
    As I start to install my new Al Knoch carpet underlayment in my 65 conv. I am noticing "wrinkles" in the rubber top coat where the padding was folded when placed in the box and shipped. I am unable to get these wrinkles out upon installation in the car. Will these wrinkles show up when I install the carpet over the underlayment or should I proceed and not worry about it?
    All the rear underlayment has wrinkles, the front is somewhat better.
    I tried heat from a heat gun to no avail. also tried Florida hot sun. It appears once this rubber is folded and pressed in a box it has a memory and the wrinkles in the rubber top coat of the underlayment are permanent.
    Anyone else experience this problem?
    Any help appreciated.
    Jim 941 531 3147
  • Jim D.
    • 2884
    Re: 1965 carpet underlayment wrinkles
    I bought the same underlayment. It's quality and where it ended up are the same - GARBAGE.
    • Jimmy B.
      • July 31, 1980
      • 584
      Where did u buy your 2nd set of underlayment from??? Was this good quality and no wrinkles
