Setting Timing C2 1966 BB - NCRS Discussion Boards
  • Larry S.
    • September 19, 2007
    • 204
    I want to check/adjust the timing on my 66 427-450 car with TI ignition. I am not sure if I connect the timing light the same way as a points distributor? Also how do I connect a portable tach/dwell meter? I know that the dwell wont be readable (I think) with a TI ignition.
  • Patrick B.
    • August 31, 1985
    • 2017
    Re: Setting Timing C2 1966 BB
    The timing light connects the same way as with point distributor. Never tried a tach/dwell. Just used the car tach or the RPM reading on my new timing light.
