I have the original carb' on my 66 L 79, but unfortunately with a stripped' thread in the main body casting. I am looking for a dependable shop recommendation for repair/refurbishment.Also, I have noted Corvette Central offers new' 4160's - w/correct List 3367 identification. Has anybody installed one of the new' units and have thoughts to offer?thanksBill
Holly List 3367 rebuild/replacement
Re: Holly List 3367 rebuild/replacement
Only place I know that sells new vintage Holleys is in Op Alabama-can give you # if you like. Maybe CC gets theirs from them. The new ones are similar but have some improvements that make them slightly different from back when. Even if you get a new one, don't assume it's set up correctly or perfect from factory. I bought one. secondaries kept flooding; found out it had a pin hole in float. Sure just a fluke, not saying the design is bad, but still...- Top
Which thread is stripped, more than not this can be repaired very easily.
Take it to a good machine shop and have a helicoil installed.- Top
Bill,I have the original carb' on my 66 L 79, but unfortunately with a stripped' thread in the main body casting. I am looking for a dependable shop recommendation for repair/refurbishment.Also, I have noted Corvette Central offers new' 4160's - w/correct List 3367 identification. Has anybody installed one of the new' units and have thoughts to offer?thanksBill
If Jerry Luck is still restoring Holley carbs, then he could fix your original carb. He's in MO, but I don't have any contact info for him.
Gary- Top
Eric Jackson at Vintage Muscle Car Parts or Jerry McNeish could also repair it rebuild/restore it if needed. Would probably be he best way to go if carb is original. Don't know if I would trust a regular machine shop. IF you are interested in the new Holleys, improved design but not like older originals in some respects: Specialty Parts Warehouse, Op AL, (334)493-1240..- Top
