69 complete rear leaf spring, big block - NCRS Discussion Boards
  • Don W.
    • September 30, 1997
    • 492
    Any suggestions on where to buy a complete rear leaf spring assembly for judging? I currently have a mono-spring installed from the prior owner. Thanks...Don
    • 6950
    Re: 69 complete rear leaf spring, big block
    Don, flea bay, Driveline, craigslist, it will take some time to find a good spring. Just keep in mind its a used piece, there is a risk. About the only reproduction spring that is correct is the 7 leaf from Americas finest Corvettes. Eaton spring from Detroit Mich. has a pretty close 9 leaf reproduction spring but not as the original 9 leafs.
    • Don W.
      • 492
      How about the Dr Rebuild set-up?
        • 6950
        Don, No one makes a 100% correct spring If you want something that's close Eaton Spring is the only choice. there maybe a correct one down the road. My understanding is the Americas finest Corvettes maybe in the process, At least that's what he told me a few years ago at Corvette of Carlisle.
        • Don W.
          • 492
          I need a 7-leaf as I have a 427 and I think the heavy rated 7-leaf is to go with big block cars if I'm correct. I open to corrections if I'm not correct.
          • Don H.
            Moderator
            • June 16, 2009
            • 2269
            America's Finest Corvette is re-making the 7 leaf spring. Also, suggest you run a wanted ad for an original in the NCRS Classified Ads forum.
              • 6950
              Don, I am not 100% sure, But if your car has a rear stabilizer bar it must be a 7 leaf. if so Americas finest corvette in California sells the correct spring. Lets see if some else answers on the big block spring. If you have a 68/69 JM manual it should spell it out in the chassis section.
                • 43247
                Don------
                The 7 leaf rear spring was supplied as part of the F-41 HD suspension option. It was AVAILABLE with L-71 but it was not part of the L-71 engine RPO. Only slightly over half of the Corvettes equipped with L-71 were also equipped with F-41.
                So, how can you tell if yours was one of them:
                1) tank sticker
                2) front springs would have 0.7" wire diameter
                3) assuming that the rear shock mount support shafts are original, check for forging number:
                3820929-30= standard suspension
                3829265= F-41 suspension
                  • 43247
                  Edward-----
                  Rear stabilizer bar was part of big block engine options; it was not part of ANY 1965-73 F-41 option.
                  The 7 leaf rear spring was part of 63-74 F-40/F-41 HD suspension option. For 1969 it was available only with L-71 and a required option for L-88/ZL-1.
                    • 6950
                    thanks Joe
                    • Patrick B.
                      • August 31, 1985
                      • 2003
                      The 7 leaf spring is the F-41 spring that is much stiffer than the 9 leaf spring that was standard on both big blocks and small blocks. Unless you are drag racing or road racing you will hate it. It is surprising that a reproduction company would focus on this low volume part when so many people desire a perfect 9 leaf repro. I put a 7 leaf spring on my 70 LT1 years ago to prevent binding and breaking half-shaft U-joints drag racing. I finally got around to putting the original 9 leaf spring back on and the car is so much more comfortable to drive.
                      • Don W.
                        • 492
                        Thank you Joe. I knew if I waited a while that I'd get the correct info. So, I have the base 427/390 HP with TH400 auto trans in a couple and know I know the 9-leaf is correct to apply. My car is originally from Canada so I have GM transfer data for the car and there is no info on HD suspension. It has this info:
                        GM Canada Import Documentation
                        Production Plant = St. Louis, MO
                        Shipping Date = Nov 17, 1969
                        Engine = 427 CID 390 HP 4bbl Turbo Jet V8
                        Dealer: Stedelbauer Chev Olds Ltd. Edmonton, AB Canada
                        Trim: Std Black Vinyl
                        Paint: 980-Riverside Gold
                        Options: A01; C50, GS2, G81, J50, K05, L36, M40, N40, PU9, U69; W84; ZQ4
                        I'm not sure what option code GS2 is unless it's my typo from hand transferring that data into a word many years ago.
                        • Edward B.
                          • March 29, 2013
                          • 691
                          Don, RPO GS2 was the 3.08 Posi rear axle code.
                          Ed
                          • Don W.
                            • 492
                            Hi Ed...too bad GS2 doesn't stand for Grand Sport 2....Don
                            • Don W.
                              • 492
                              Any comments on the correctness of this ebay unit? I current have a mono spring; what other components would be needed to mount this?
