68 seat belt installation - NCRS Discussion Boards
  • Ernest C.
    • July 31, 1991
    • 115
    I'm in the process of installing original seat belts in my 68. I know where the retractors bolt thru the floor, but is the retractor under the carpet or does it mount on top of the carpet?
    Thank you
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 68 seat belt installation
    It's been a long time since I restored my 68 but I seem to recall it was under the carpet. The strap and buckle was feed thru a cut slot thru the carpet adjacent to the seat. My car is early 67 build if that makes a difference.
    • Ernest C.
      • July 31, 1991
      • 115
      Thanks, that is what I thought but I took this car apart 15 years ago and am now finishing it.
      • Russ T.
        • May 31, 1989
        • 113
        Here's a useful thread that I initiated on this topic:
        https://www.forums.ncrs.org/showthread.php?105372-Need-Confirmation-on-1968-Corvette-Seat-Belt-Layout&goto=newpost
        You can buy the grommets on e-bay, too. Per dicussions on this site, they are correct for 1968 too, although
        only listed as 1969-1971:
        1969-1971 C3 CORVETTE SEAT BELT CARPET INSERT GROMMETS
        I have an early '68 with the seat belt retractors as well. Others here have weighed in on the subject too.
        Russ Trotter
        NCRS #15044
        • Gene M.
          • April 1, 1985
          • 4232
          [QUOTE=Russ Trotter (15044);709765].......................
          only listed as 1969-1971: ..................
          I feel pretty sure the seat belt grommets were not on the early '68. My evidence shows that only a cut slit in the carpet for the belt to feed thru was done.
          The '68 model year was full of a lot of running changes so it's possible it was added later............
          • Rich G.
            • August 31, 2002
            • 1397
            I have a July 68 built coupe with original carpets and no grommets. It has original belts and no retractors. Are retractors missing on mine or were they only on earlier cars? I don't recall what the TM/JG says.
            Rich
            • Gene M.
              • April 1, 1985
              • 4232
              Rich
              Rich,
              I would suggest you remove the seat and lift up the carpet to see the retractors. Possibly they are there but frozen so they don't retract. My history has seen this more than not. But then again 68 had a lot of running changes.
              • Rich G.
                • August 31, 2002
                • 1397
                Originally posted by Gene Manno (8571)
                Rich,
                Thanks Gene. I will take a look.
                Rich
                • Terry B.
                  • August 31, 1999
                  • 607
                  My December built '68 did not come with retractors on the seat belts.
                  Terry Buchanan
                  Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                  Corvettes Owned:
                  1977 Coupe
                  1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                  2003 Electron Blue Coupe
                  2019 Torch Red Grand Sport Coupe
