Re-dyeing while vinyl door panels on a '64 - NCRS Discussion Boards
  • Garry E.
    • September 30, 2002
    • 240
    Does anyone have the color code number (or mixture formulation...) to re-dye white vinyl door panels on a '64 convertible...?Garry Eastwood#38705
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Re-dyeing while vinyl door panels on a '64
    Gary,
    The original door panels were not dyed. They were molded in color. But to replicate the color Corvette America has a spray to make them a satin white color. It is not a dye but rather a thin, high pigment paint. It will wear with use, but can be redone to look fresh again. IMO it looks good but one can tell your secret as it gets some wear......
    • Leif A.
      • August 31, 1997
      • 3646
      Garry,As Gene has mentioned, your original door panels are molded with the color. Have you tried scrubbing them really good with a nylon brush and Simply Green or similar product?Leif
      Leif
        • 6950
        Gary, Corvette America also make a primer for vinyl. This will aid with the paint adhering to the panels.
        • Gene M.
          • April 1, 1985
          • 4232
          Ed, Gary,
          I don't think adhesion is not the problem but that the finish wears if you use your car any amount. My driver 65 is now in need of a "refresh" on door panels from "enjoyed usage". Still not too bad looking. But not perfect. Just be willing to keep up finish and I think you will be pleased with the results.
          • Loren L.
            • April 30, 1976
            • 4104
            Garry: Take both of your armrests off and clean them and evaluate just how close they are to the finish your seeking; then call Young Paint Sales (19th Ave between Indian School and Camelback - west side) and make an appointment with Scott to go after the color you're seeking.
