What would make my 1977 L-82 motor spin the temperature guage in a 360 degree mode? This happened for a few minutes . It finally settled down . Had to laugh as I was watching this show!
Temperture gauge C3
Re: Temperture gauge C3
Frank,
It's possessed by Satan!!!!!
Most small gauges have two mechanisms to keep them from jumping around and in your case flying around. First there is a magnet to orient them in the North-South Direction and then there is a dampening fluid to keep them from jumping around when you cross the railroad tracks. Your gauge is getting old and the fluid has been lost along with the magnet not being as strong as it was in 1977.
You need to order a new gauge and it will probably last for another 36 years.
JR- Top
Joe, I have a question, When the fluid damper has lost its fluid, Does this mean the gauges are no longer repairable?Frank,It's possessed by Satan!!!!!Most small gauges have two mechanisms to keep them from jumping around and in your case flying around. First there is a magnet to orient them in the North-South Direction and then there is a dampening fluid to keep them from jumping around when you cross the railroad tracks. Your gauge is getting old and the fluid has been lost along with the magnet not being as strong as it was in 1977.You need to order a new gauge and it will probably last for another 36 years.JRNew England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
