Jack Instruction Card - NCRS Discussion Boards
  • Leif A.
    • August 31, 1997
    • 3650
    My jack instruction card has, basically, disintegrated over the years and I have a new one purchased from LIC. The instructions say to install with rubber cement. My question is rubber cement on the back only OR rubber cement on the back and then spread over the top to protect? Was the original rubber cement slathered on the board as well and, if so, how far outside the borders of the instruction card.
    Thanks All
    Leif
    • 6955
    Re: Jack Instruction Card
    Lief, I used 3M spray tack, just place the label on the board and mask the area around the perimeter of the label then lay some paper down and tape it down and spray the 3M and let dry slightly then place label down carefully as it sticks the moment it is placed.
    • Leif A.
      • August 31, 1997
      • 3650
      Ed,
      Thanks for the speedy reply. I'm guessing I place the label face down before spraying with 3M spray tack. Also, are you recommending spraying the back of the label as well as the board? I'm picturing using the jack card as a template and then spraying the board.
      Leif
        • 6955
        Leif the label is paper, it will soak it up and screw up the label, just spray the board. also the labels were not placed perfectly just use your outline of your old label.
        • Leif A.
          • August 31, 1997
          • 3650
          Gotcha...thanks, Ed
          Leif
          • Mike E.
            • February 28, 1975
            • 5141
            What are you trying to achieve? Typical factory production, or pretty? Leif, I should be able to remember what year you have, but have forgotten. That would help me give you a better answer.
            • Leif A.
              • August 31, 1997
              • 3650
              Mike,It's a '67 Coupe. To answer your question, I would be leaning more towards factory production.
              Leif
              • Stephen L.
                • May 31, 1984
                • 3162
                Leif, here is an original jackboard showing sticker locations and the JPSTEVENS label
                • Leif A.
                  • August 31, 1997
                  • 3650
                  Perfect, Stephen...that's exactly what I was looking for.
                  Leif
