69 headlamp bezel screws - NCRS Discussion Boards
  • Don W.
    • September 30, 1997
    • 492
    Are these correct screws to attach the chrome headlight bezel? I lost one and mine are black; this screw set is chrome.
    Paragon Number: 8724K
    GM Part Number: 9416444 & 9427748
    https://www.paragoncorvette.com/sear...archTerm=8724K
  • Ralph S.
    • February 1, 1985
    • 935
    Re: 69 headlamp bezel screws
    Yes those are the ones you need
    • Bill C.
      • July 15, 2007
      • 904
      they will work
      just be careful screwing them in.
      I personally think they are just a tad bit longer than the originals - I compared to my real ones.
      Also - the screw head for the machine screws is a little thinner...
      I ran a chase in mi pot metal light assemblies to be sure all the threads were clean of any corrosion.
      Bill
        • 43248
        Don------
        Chrome headlight bezel? No 1963-82 Corvette ever originally used a chrome headlight bezel.
        • Leif A.
          • August 31, 1997
          • 3645
          Are these correct screws to attach the chrome headlight bezel? I lost one and mine are black; this screw set is chrome.Paragon Number: 8724KGM Part Number: 9416444 & 9427748https://www.paragoncorvette.com/sear...archTerm=8724K
          Don,Are you asking about the stainless retaining ring? Or, did you have your bezels chrome plated?? What to give you an informed answer.
          Leif
          • Don W.
            • 492
            I actually meant the headlamp retaining ring. The top one was showed up 1st on paragon; then I went back and did another search and found the correct 12 set of bezel screws. Sometimes it hard tp do thing from work in the office from memory when you don't have the vette in front of you nor have you looked at that area in a while. Thank you Leif...Don
              • 43248
              Don-----
              OK, that's different. The GM part numbers you provided in your first post are for the bezel. However, now that we know what you really need, besides fastening the retainer, those are actually the headlamp aiming screws. You can still obtain the screws you need from GM under GM #5966249
              • Bill C.
                • July 15, 2007
                • 904
                the ones listed in paragon are generic.
                GM headlamp retaining ring screws were WAY different. They had a small head and pointy ends.
                There was a guy on ebay selling sets of the correct ones.
                I purchased a set for the 1969 I just finished.
                LINK:
                even though it says Pontiac - they are the same for a Vette
                  • 3416
                  Hi,
                  These pictures are from my 71, but if 69 cars are the same I believe the ring mounting screws are as Bill described .. a very small round head with a pointed, threaded, shaft.
                  The pointed shape is shown more clearly in the second picture.
                  In these pictures you can also see one of the headlight aiming screws.
