Door Keys for 1965 - NCRS Discussion Boards
Door Keys for 1965
  • Kerouac B.
    • May 5, 2014
    • 48
    Door Keys for 1965
    Hi Everyone:
    I recently bought a 1965 Coupe, and I only got one key with the car. That key (which appears original) does not open the car doors. I'm assuming the doors are replacements. Is there a place where I can buy new door lock cylinders with keys? I realize I probably can't match new door locks to the ignition key I currently have, but I need to be able to lock this car. Any suggestions? Thanks.
    Matt
  • Don H.
    Moderator
    • June 16, 2009
    • 2257
    Re: Door Keys for 1965
    Hi Matt
    see this thread from two days ago.
    https://www.forums.ncrs.org/showthre...9-Tumbler-work
    Pete Lindahl is the man, and Gary Beaupre also does good work.
    drop me an email for the details.
    • Gary B.
      • February 1, 1997
      • 7018
      Matt,
      I wouldn't automatically assume that the door locks have been replaced. It's actually more likely that the ignition lock has been replaced. Which would be a better situation for you since it's possible to fix the ignition lock to match the doors much easier than vice versa. I would suggest taking a look inside the doors and look at the door locks. If the door locks are original, the 4-digit key code will be stamped into the case of each door lock, which can be visualized most easily if the door locks are removed.
      Gary
      • Kerouac B.
        • May 5, 2014
        • 48
        [QUOTE=Gary Beaupre (28818);708500]Matt,
        Thanks for the insights, Gary. But I know from the documents I have regarding the cars' restoration that the doors (at least the driver's door) is a replacement. What I'm wondering -- worst case -- can I get some new locks installed and deal with the fact that I will have two keys doing the job that one key used to do. I just want to lock this car! Thanks.
        • Russ S.
          • April 30, 1982
          • 2162
          Door locks can be changed to match the ignition.
          • Kerouac B.
            • May 5, 2014
            • 48
            That's good news, Russ. How do I go about that? Thanks.
            Matt
            • Russ S.
              • April 30, 1982
              • 2162
              Take your door locks out and send them and the key that you want to operate them to Pete Lindahl. 505-663-0995 or 505-412-2389 cell.
              • Kerouac B.
                • May 5, 2014
                • 48
                Thank you, Russ.
                • Chris E.
                  • November 3, 2006
                  • 1326
                  I second the recommendation to work with Pete. Very knowledgeable, great work and turnaround time. He did the locks on my '67 and I'm very happy.
                  Chris Enstrom
                  2011 Z06, red/red
