I just installed my new P/W wiring harness through the doors . On the right I have a yellow and light green, the left has green and white.
Now I know that the AIM UPC- A-31 A-2 tells me exactly what to do . The problem is I have no idea what they are showing me ! Without showing me what is the top or bottom of the plug , the vertical and the horizontal slots can be interchanged quite easily ! To make matters worse it appears to me that they show the wires inserting from the front of the plug , not the rear.
Am I correct in thinking that the picture show the front of the plug with the locking tab to the right side ??
The one thing I do understand is the note that states, (paraphrasing a bit ) "when correctly wired everything works correctly" ........................... I would like that !!!!
Can someone explain it to me in short simple words , or is it much ado about nothing ?
Secondly , when I removed all that stuff way back when , I bought a new motor for the drivers side and installed it . I now see it has no ground terminal attached to the motor as does the original one . Am I correct in assuming that the ground wire can be attached to any part of the motor I can find a screw to ?
Jim
Jim
