Will be buying new 2014 Silverado Shortbed. Had to search for the one I wanted to meet my specs. (Too late to order them now) Only ones with all
the trailer options had 3.08 gears. My GCWR is around 11000 pulling my Corvette in enclosed trailer. The new Silverado's have the new 6 Speed
Auto. Trans. The GM specs. with my "standard box V8" for GCWR(3.08) is 12000 so I am within their specs. We all know the final drive ratio is trans. X
rear end not just rear end. Below is a comparison of new vs. old transmission ratio's.
I'll make it easy for ya. Here are the transmission ratios for the old 4 speed trans GM put in the half tons prior to 2010. And here is the trans ratios for the current 6 speed they use now in the half tons. You can see the 3.08 is a little better than the old 3.73 and the 3.42 is a lot better than both the 3.08 and the old 3.73. People get lost in the rear end gearing when it's a combination of both the rear end gearing and trans gearing.
4L60E with 3.73
1st-3.059=11.410
2nd-1.625=6.061
3rd-1.000=3.730
4th-0.696=2.596
6L80E with 3.42
1st -4.027=13.772
2nd-2.364=8.084
3rd-1.532=5.239
4th-1.152=3.939
5th-0.852=2.913
6th-0.667=2.281
6L80E with 3.08
1st -4.027=12.403
2nd-2.364=7.281
3rd-1.532=4.718
4th-1.152=3.548
5th-0.852=2.624
6th-0.667=2.054
So: with all this info does anybody see a problem? Need comments. Larry P.S. My specs. are very unique (Color,length, trailer controller and etc.)
4L60E with 3.73
1st-3.059=11.410
2nd-1.625=6.061
3rd-1.000=3.730
4th-0.696=2.596
6L80E with 3.42
1st -4.027=13.772
2nd-2.364=8.084
3rd-1.532=5.239
4th-1.152=3.939
5th-0.852=2.913
6th-0.667=2.281
6L80E with 3.08
1st -4.027=12.403
2nd-2.364=7.281
3rd-1.532=4.718
4th-1.152=3.548
5th-0.852=2.624
6th-0.667=2.054
