Battery Cable routing - NCRS Discussion Boards
  • Chuck R.
    • April 30, 1999
    • 1434
    Hello all, hopefully this will only require a quickie response.
    Does the battery cable run behind the insulation materials or is it buried behind them?
    Thanks, Chuck
  • Chuck R.
    • April 30, 1999
    • 1434
    Re: Battery Cable routing
    I should have said does the battery cable run "in front" of the insulation materials or is it buried behind them. I can't type and I'm getting worse
    • Bill C.
      • July 15, 2007
      • 904
      the positive cable is strapped down and behind the transmission tunnel and any other insulation material
      i am 98% sure .. :-)
      • Paul O.
        • August 31, 1990
        • 1716
        Chuck
        The cable is first installed then the insulation is installed over it so cable is under the insulating blanket.
        • Chuck R.
          • April 30, 1999
          • 1434
          After installing the cable and in preparing to install the insulation blanket materials I just needed to hear it from those in the "Know" that I didn't put the cart before the horse.
          Thanks for the fast responses guys I appreciate it. Chuck
