1967 400hp L68 "JC" Engine Stamp Pad - legit or a fake? - NCRS Discussion Boards
  • Mark S.
    • January 26, 2013
    • 88
    I am considering a 400hp L68 Convert and would appreciate guidance on the attached engine stamp pad. Please weigh in if this pad is legit or a fake. Many thanks in advance.
    1967 Corvette - 400hp - Engine Stamp #1.jpg1967 Corvette - 400hp - Engine Stamp #2.jpg
  • Jody B.
    • March 1, 1991
    • 108
    Re: 1967 400hp L68 "JC" Engine Stamp Pad - legit or a fake?
    There are several of non-typical marks on the pad and the #2 & #8 are different in each stamp. JMO, but I would proceed very cautiously....
    • David B.
      • April 1, 1988
      • 42
      Mark - FWIW, here's a photo of an engine pad which appears (to my eyes at least) to be stamped with the same vin derivative as shown in your photo. Admittedly, not the greatest resolution. It was collected from an internet source back in 2005. The assembly code suffix HO = a 327/300 hp with powerglide.
      • Mark S.
        • January 26, 2013
        • 88
        Thank you Jody. Was this a possible scenario on the line?
        • Larry M.
          • January 1, 1992
          • 2691
          Based on the Birthday Book, Corvette #4248 should have been made about November 11. This is about 5 weeks after the 427 engine you showed was built, which is a bit longer than usual. The approximate November 11 car build date better fits the small block build date that David posted about, although even this is a bit tight. But the Birthday Book can be off a few days. Also November 11, 1966 is a Friday.
          What is the 427 engine block casting date??
          I don't like the engine build date stamping on the 427 motor, it is too far off the pad and also just doesn't look right to me. The 427 engine blocks were stamped without the heads at Tonawanda. This one looks like it was stamped with the head on.
          The 327 engine with the same VIN derivative is a base engine with a Powerglide…………..not one that you would suspect being restamped…..although anything is possible.
          Larry
          • William C.
            • May 31, 1975
            • 6037
            I'd like to see a much more crisp picture before making any judgement, with much less reflection off the machined surface...
            Bill Clupper #618
            • Dick W.
              • 10483
              Larry I know where there are two 250 hp restamps. Never rule out anything.
              Dick Whittington
              • Mark D.
                • June 30, 1988
                • 2151
                After what Dave Borror posted, my advice would be...take off running, don't look over your shoulder, run until your about to pass out then, keep running.
                Kramden
                Kramden
                • Mark S.
                  • January 26, 2013
                  • 88
                  I agree Larry, the Assembly stamping hugging the bottom edge of the pad makes me skeptical. I commonly see this stamping in the middle to upper portion of the pad? I guess after a quick couple of boilermakers over lunch, anything was possible in those afternoon hours....
                  • Dick W.
                    • 10483
                    Kramden
                    Agree with the "bus driver" Run Forrest, Run
                    Dick Whittington
                    • Page C.
                      • February 1, 1979
                      • 802
                      Google search of the vin for this car shows a red/red 427/400 air cond. side exhaust, head rest, bolt on wheels, etc. Then the photo of a 327/300 powerglide engine shows up with what looks like the same vin derivative. This car is the first I have seen with both a small and big block engine option at the same time. It also seems to float around in varies auctions. Would love to see a trim tag photo.
                      • Steve B.
                        • March 1, 2002
                        • 1190
                        Kramden
                        I agree 100% with Mark. This is why certain rare and desirable models trade at such high multiples compared to many of the other comps that are available through ebay etc.
                        • Ara G.
                          • January 31, 2008
                          • 1108
                          Post #4 from Dave puts this one to rest....Forever....
                          • Tim G.
                            • March 1, 1990
                            • 1375
                            I remember years ago looking at a 1967 400 horse black coupe in Northern California. Noland Adams was along with me and he noted that when he looked at the same car in 1975 it was a 390 horse black coupe. He had kept note of nearly every Corvette he looked at over the years.
                            • Erik P.
                              • October 14, 2015
                              • 12
                              Reviving an old thread. Sorry about that!
                              Isn't it possible for two engine pads to have the same serial number if one of them comes from a coupe and the oither from a convertible?
