survivor without original engine?? - NCRS Discussion Boards
  • Anthony S.
    • April 30, 1998
    • 156
    Really?...was told that a car was a survivor and the car does not have the orginal engine? I can't really agree...
  • Dick W.
    • 10483
    Re: survivor without original engine??
    ROTFLMAO. . Sounds like a fairy tail, Once upon a time
    Dick Whittington
    • Michael J.
      • January 27, 2009
      • 7167
      • Harry S.
        • July 31, 2002
        • 5344
        Isn't a survivor without the original engine an oxymoron?
        • Michael J.
          • January 27, 2009
          • 7167
            • 11692
            Actually, until this year you could get a Survivor Award from Bloomington without having the original engine. You only needed to pass 3 of 4 areas on the car, and if you passed the other 3 areas, you got the award.
            So yes, it is possible.
            • Kenneth B.
              • August 31, 1984
              • 2091
              Whadda joke
              Again It's all abut the money. As I remember it was like that when BG started that award.
              • Gene M.
                • April 1, 1985
                • 4233
                Assuming at the other 3 sections are good. Does that allow for a Corvette to obtain a Survivor Award with a "409" engine?
                  • 11692
                  Up until this year, yes.
                    • 15632
                    Gene,
                    Are you still looking for the C1 409 to put through BJ?
                    • Gene M.
                      • April 1, 1985
                      • 4233
                      Gene,
                      No, but I was thinking. If one was to build a resto mod style Corvette using an after market tube frame modified to accept all the original components. The points loss would be less than one percentage point. Full deduct for frame. Now everything would need to mount and be assembled just as original to avoid points loss on those items.
                      By point allocation, do the math, it would be possible to top flight without the single biggest piece of the car (frame) being remotely correct.
                        • 15632
                        Of course, given the low points assigned to the frame mostly because it is very difficult to adequately judge the bulk of the frame. Secondarily there are so many small pieces to the chassis there are few points available to move to the frame should one be so inclined.
                        I think some might argue that the engine is the largest piece of the car. It is certainly the weightiest, and many would argue the most important.
                        • Gene M.
                          • April 1, 1985
                          • 4233
                          Most important vs largest points persons in different directions. But your point that the engine is most important is justified. If I was looking to buy a car with a rusty frame I can fix/repair and restore it. But if the original engine block has a crack thru the lifter bores, I'd walk away.
                          So yes engine #1, then virgin body with good bird cage also #1, and frame #2. It all depends on one's skill set. I can assure you birdcage work is no fun. Good discussion but I'm starting to get off topic. sorry
                            • 15632
                            And I am enabling you. Sorry. Back to the regularly scheduled topic.
