1970 Oil Cap - NCRS Discussion Boards
1970 Oil Cap
  • Terry B.
    • April 1, 2003
    • 50
    1970 Oil Cap
    Does anyone know if the gasket on a 1970 350/350 oil cap is replaceable? Mine is leaking oil onto the valve cover and since the cap is original, I would like to replace just the rubber gasket if possible.
    Web Master Miami Valley Chapter 2010 to present
    Newsletter Chairman Miami Valley Chapter 2003 to 2011
    Events Chairman Miami Valley Chapter 2010
    Miami Valley Chapter Secretary 2012 to 2015
    Miami Valley Chapter Media Chairman 2016
    Miami Valley Chapter Judging Chairman 2017 to present
    • 43248
    Re: 1970 Oil Cap
    Terry------
    I believe the gasket is cellulosic (i.e. "cardboard") and not rubber. If it were rubber, you probably could replace it by stretching it on. However, cellulosic material does not stretch very well.
    • Michael F.
      • 745
      Re: 1970 Oil Cap
      wonder how they got it on in the first place or manufacturing process of cap?
      Michael
      70 Mulsanne Blue LT-1
      03 Electron Blue Z06
        • 15616
        Re: 1970 Oil Cap
        My guess would be they assembled the cap with the gasket in place. If you had the equipment to set the center rivet, you could do the same.
        • Terry B.
          • April 1, 2003
          • 50
          Re: 1970 Oil Cap
          Joe, Thanks for the reply.
          Mine is definitely rubber, although the cap has all the right markings, maybe it isn't original after all. Have had it judged numerous times with no comment regarding the gasket.
          • Paul O.
            • August 31, 1990
            • 1716
            Re: 1970 Oil Cap
            Check with Joe Perri he can help you.
            Paul
            • Terry B.
              • April 1, 2003
              • 50
              Re: 1970 Oil Cap
              Good idea Paul, I was thinking the same thing
