1969 Radiator - NCRS Discussion Boards
1969 Radiator
  • Howard K.
    Infrequent User
    • September 30, 1979
    • 17
    1969 Radiator
    Does any one have any information on radiator part numbers for 69 Corvettes and how to interpret and decode the radiator ID tags? Thanks for any help you can give me.
    • 43246
    Re: 1969 Radiator
    Howard------
    There were 6 different radiators used for 1969 Corvettes as follows:
    GM #3155316----all 300 HP with manual transmission; some L-46, especially early; aluminum and used with external supply tank
    GM #3018803----some L-46, especially late; copper/brass; no external supply tank; code MK9
    GM #3018802----all 300 HP with automatic transmission; copper/brass; no external supply tank ;
    GM #3018571----427 with manual transmission, except L-88/ZL-1; copper/brass; uses external supply tank; code MJ9
    GM #3019190----all 427 with auto transmission including L-88/ZL-1; copper/brass; uses external supply tank; code MH9
    GM #3007436----L-88/ZL-1 with manual transmission; aluminum; uses external supply tank
    • Howard K.
      Infrequent User
      • 17
      Re: 1969 Radiator
      Joe, Thanks for your response. Please call me if you ever need anything in the Dallas area or I can assist you otherwise. Howard Key 214-369-0600
