Re: '63 Tie-Rod Clamps - NCRS Discussion Boards
  • Douglas C.
    • September 30, 1988
    • 237
    Hi,
    I am interested in knowing which is the "correct" tie-rod clamp for my early (Dec. '62) convertible.
    In the attached picture - the clamp on the left is the repro with twin ridges, and the one are the right is the one originally on the car (single ridge in middle).
    I know sometimes there are differences with the early '63's and just making sure this isn't one of them.
    Thanks for any responses.
    --Doug
    • 43247
    Originally posted by Douglas Cline (13644)
    Hi,
    --Doug
    Doug------
    The 2 ridge clamp is the original style for 1963 through at least 1972 known as GM #3742920 through about 1966 and GM #3902938 from 1967 through at least 1972. The single rib style was GM #3954397 and used after 1972 in PRODUCTION and later for all 1963+ SERVICE.
    Last edited by Joe L.; May 22, 2014, 02:59 AM. Reason: complete revision and correction
    • Douglas C.
      • 237
      Joe,
      Thanks for the response - the single ridge clamp sure looks a lot sturdier than the repro - even the nuts on the clamp bolts are thicker!
      --Doug
