Interior screws 1962 - NCRS Discussion Boards
  • Ted K.
    • August 31, 1994
    • 337
    Putting the interior back into my 1962 that I took out several years ago. Where can I get pictures or information showing which screws go where. I have the Assembly manual and Judging manual but neither addresses that subject. More specifically kick panels. Thanks
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    Re: Interior screws 1962
    Ted, That's a tough one.
    The repro interior screw kit has each bag marked with the application. The screws may not be identical, but should be of some help to identify. The CC kit has everything ID'd and if you look up the part#'s and the pictures of each it should give you an idea.
    edit....
    the 341149 kickpanel set is shown below. The 2 longer screws are for the lower rear corner and thread into the metal wire cover so make sure the hole in it is big enough or they break.
    Rich
    • Ted K.
      • August 31, 1994
      • 337
      Thanks just what I needed
