Steering Bump 1959 - NCRS Discussion Boards
Steering Bump 1959
  • John C.
    • September 30, 2001
    • 130
    Steering Bump 1959
    Is this caused by a steering box problem or a tie rod problem
  • Terry D.
    • May 31, 1987
    • 2696
    Re: Steering Bump 1959
    You need to define "steering bump" not sure what you mean.
    • Jim L.
      • September 30, 1979
      • 1816
      If you are referring to a point in turning the steering wheel at which the steering effort become momentarily greater, this is due to defects inside the steering box. Typically, the sector roller has either dents or small chunks of metal missing. There are rebuild kits with new sector rollers and new worm gears.
      Jim
      • Mike T.
        • January 1, 1992
        • 568
        John, when I bought my 61, the steering had a real 'notchy' feeling to it. Seemed like a serious of 'speed bumps' as you turned the wheel. Finally pulled it apart and found the sector gear damaged. The only fix is to rebuild it with new parts.
        Mike T. - Prescott AZ.
