My car is a 66 L72. My uncle bought it used in 68 or 69, I'm pretty sure it's an original L72 (427 / 425) car. So, assuming it's a factory L72, transistor ignition (TI) would have been automatically installed in St. Louis. It has been hit in the front at least twice. The TI module sure does not look like it was mounted to the radiator support correctly. It was only held by one bolt (probably because two of the three mounting ears are busted off.) The one bolt that was "holding" it could not be tightened all the way because it interfered with the L bracket holding the radiator support to the left fender. I don't see three holes to mount the TI amplifier to the radiator support. Did all 66 radiator supports come predrilled for TI? I glanced at the AIM, but I must admit that I am not very good at interpreting mechanical drawings. Do you all think my car originally had TI? If so, how do I mount the amplifier properly? I have attached some pictures, including the wiring near the distributor.
