simple 70 Differential Vent ? - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    Should there be any type of pressure spring or check ball inside the differential vent or is it just a hollow white tube basically with a white cap?
    Bill
    • 6942
    Re: simple 70 Differential Vent ?
    Bill, the vent is only as says a vent, It does not have a spring or check ball internally. Pretty simple.
    • Michael G.
      • March 2, 2008
      • 485
      It is as you described. Simple tube and cap. No internals.
        • 3415
        Hi Bill,
        The white tube with white cap is nice to have! $$
        I believe there were later vents with a white tube and gray cap although they still have the Danco name and patent number on them.
        I have my original tube, but the cap was missing.
        • Bill L.
          • February 1, 2004
          • 1403
          Hi Bill,
          HI Alan,
          Thank you. I am getting ready to reinstall the entire rear assembly.
          Bill
          • Bill L.
            • February 1, 2004
            • 1403
            Thank you Edward.
            Bill
            • Bill L.
              • February 1, 2004
              • 1403
              Thanks Michael.
              Bill
              • Rey S.
                • April 1, 1995
                • 277
                If you don't care about correctness just put a length of tube or hose either straight or bent over. Straight is OK as long as the car is for some reason turned upside down. Most cases upside down means an accident, in witch case you probably wont care if the differential leaks.
                • Bill L.
                  • February 1, 2004
                  • 1403
                  I have the original.
                  Thank you for the idea Rey.
