My good friend and fellow member Chuck McSheehy's fully restored Top Flight '65 Fuelie has a very strange issue. We've been diagnosing it for some time now, scratching heads, loosing hair, and getting a bit frustrated.
Here's what's happening......
On acceleration OR deceleration, the car pulls noticeably to the right. For example, at about 35mph in second gear, a full throttle launch will cause the car to pull right like it's being steered that way. After a steering wheel correction to get it straight, then cruising at about 50-60 mph, let off the throttle abruptly and the car pulls to the right again.
I drove it myself and can feel it. Very scary.
We fully inspected all steering and suspension pieces, which have been fully rebuilt over the last few years as part of his restoration, etc. All is fine. Ball joints, linkages, tie rod ends, idler, control arm bushings, wheel bearing, wheels etc, all of which have been replaced or restored as part of his full body off chassis restoration a few years ago.
We brought the car to a friend's alignment shop a few weeks ago. Full 4 wheel alignment. Corrected some rear camber & some toe with shim rearrangement, and front shim work C/C and toe. The alignment came out perfect. We spent a good 2 hours on the rack to get it corrected, using John Hinckley's alignment spec guide for radial tires as the car is so equipped for road cruising off the judging field. It has knockoffs and all are tight.
Last week Chuck did some checks, and noticed the right rear trailing arm front bushing had much play, much more than the left. We decided to tackle replacement of both L & R bushings over the last few days. Upon removal of the right side bushings, we see deteriorated rubber on the periphery of the bushings, but the internal rubber seems fine to us. Both are now replaced and going back in the car today.
We're obviously going to have to get the alignment redone again. We're hoping this right rear bushing play was the cause of the unusual launch pulling to the right. But after seeing that the bushings were not totally faulty, we have reservations.
If you have any other ideas or things to check while we have it all apart please jump in with your thoughts.
Rich & Chuck
p.s. we pulled the diff to replace a leaky pinion seal while we had it apart too.
I drove it myself and can feel it. Very scary.We fully inspected all steering and suspension pieces, which have been fully rebuilt over the last few years as part of his restoration, etc. All is fine. Ball joints, linkages, tie rod ends, idler, control arm bushings, wheel bearing, wheels etc, all of which have been replaced or restored as part of his full body off chassis restoration a few years ago.
Rich & Chuck
