56 Parking Brake Flasher - NCRS Discussion Boards
  • Cathy S.
    • August 31, 2003
    • 293
    The unit that champs on the 56 parking brake arm appears the same as the one on my 54. Is the flashing unit interchangeable? 12v vs 6v.
  • Mike E.
    • February 28, 1975
    • 5141
    Re: 56 Parking Brake Flasher
    You are correct that they are different, 12v vs. 6 v. They also have different numbers (the last 3 digits of the part number) stamped in white ink on the black housing.
    • Cathy S.
      • August 31, 2003
      • 293
      Anyone know the correct number for my 56?
      • Gary C.
        Administrator
        • October 1, 1982
        • 17771
        Cathy,
        Emergency brake flasher part numbers:
        - 53-55 6V #632
        - 56-75 12V #650, GM 3711289
        - 58-60 12V #642, GM 3737979
        Have not been able to find information on the electrical differences between flasher #642 and #650.
        #650 flashers are not easy to find. #650 flasher will work for 56-57, but don't know if the flashing rates are different or not.
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Cathy S.
          • August 31, 2003
          • 293
          Perfect! Thank you!
