63 Rear Spindle Supports - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2158
    Early 63's had unique rear spindles, (no web between the legs) but were those parts replaced with the webbed parts for the start of 64 or late in 63 production?
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
  • Dick W.
    • 10483
    Re: 63 Rear Spines
    I believe you are referring to spindle supports not spindles?
    Dick Whittington
    • John D.
      • December 1, 1979
      • 5507
      Re: 63 Rear Spines
      Michael, I never knew how late in production the early spindle supports were used on the '63. It seems that is not common knowledge.
      Maybe Jorjorian will chrip in. JD
      • Michael G.
        • November 12, 2008
        • 2158
        Re: 63 Rear Spines
        Dick, yeah, I meant supports....thanks.
        Jeeez, and the auto-correct changed the title from "spindles" to "spines". It's a wonder you guys can figure out my gibberish....
        Mike
        • Wayne M.
          • March 1, 1980
          • 6414
          Re: 63 Rear Spines
          FWIW, here's off an early calendar '64. The other side is cast A_6_4.
            • 6956
            Re: 63 Rear Spines
            Early 63's had unique rear spindles, (no web between the legs) but were those parts replaced with the webbed parts for the start of 64 or late in 63 production?Thanks,
            Mike, I have a chapter member here in N.E. that has a July car 120xxx He has one spindle support with web and he has the 63 date. He may catch this post and answer you.
            • Mike M.
              • May 31, 1974
              • 8408
              Re: 63 Rear Spines
              my old 63 built last week of july 63 had a webbed and a non webbed spindle support. mike
                • 43279
                Re: 63 Rear Spines
                All------
                By the way, the casting number on the supports and the finished part number for the supports never changed. So, the addition of the "webbing" must have been accomplished by a revision to the specs for the part. The left side and right side castings were the same. The only difference for left and right sides was the machining for the finished parts.
                • Harry S.
                  • July 31, 2002
                  • 5344
                  Re: 63 Rear Spindle Supports
                  Both spindle supports in my April 63 car have the web. They are dated B 7 3. Yes they are 63's not 73's
                  I don't think a cutoff date will ever be determined.
                  • Michael G.
                    • November 12, 2008
                    • 2158
                    Harry, I think maybe you answered my question. My April car (13696) has webs and I was thinking maybe the supports had been replaced. Sounds like they could be original. I'll look for dates on them.
                    Mikey, with that one web, your car is about half prepared for amphibious work....
                    Mike
                    • Gary F.
                      • August 29, 2010
                      • 248
                      Neither spindle arm on my March 18th built 63 ( 10862 ) has the web.
                      • Bob R.
                        • June 30, 2002
                        • 1595
                        One of the supports on my May 14th 63 had no web on it. I had to replace it as it was cracked when I bought the car unfortunately I didn't bother to look for a date on it.
                        • Michael G.
                          • November 12, 2008
                          • 2158
                          It's beginning to sound like the first webbed ones arrived in late March or April. After that, they probably had multiple boxes of supports in the plant at once, some with webs, some without. Lacking a distinguishing part number, they'd have put them on the line in whatever order the box presented itself to the hilo driver, without regard for physical differences.
                          Mike
                            • 6956
                            Mike, I think its as Harry S. says its appears that there is not a clear cut date on the switch. I was looking at pics of a 63 chassis resto on Wilcox Corvettes website if I remember they a one with a closed web and one without on a original chassis.
                              • 43279
                              All-------
                              One thing to keep in mind here: I realize that the "non-webbed" supports are the correct ones for most 1963's. However, you don't suppose that GM added the "webbing" because there was no problem at all with the supports without it, do you?
