1963 Fiberglass Headlight Buckets - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1283
    Hi,I need a pair of these and I'm having a difficult time finding a decent set. Any idea where I can go to find these? EBay has a couple of pairs, but they are junk. Any leads would be appreciated.Thanks,Jerry
  • Gerald C.
    • June 30, 1987
    • 1283
    Re: 1963 Fiberglass Headlight Buckets
    Just to clarify, my car was built on 10/31/62. Just looking for the correct style.Thanks
      • 6942
      Jerry, Classic corvette fiberglass sells the 63 fiberglass skin only if that works for you. Just a note- they are made to order so expect 6/8 weeks turn around.
      • Joe R.
        • July 31, 1976
        • 4550
        Gerald,
        As you know there was two designs in 63. Yours should be the steel frame with a fiberglass shell. The fiberglass shell should be filled on each end with seam filler. The second design used the fiberglass shell but wrapped around the ends about 1 to 1 1/2 inch. The second design was much neater after installation and looked better when open. Also, the first design buckets had the frame around the headlights with screws coming in straight from the front.
        Finding a good set of first design headlight buckets for a 63 is going to take a lot of patience. Maybe Corvette Carlisle this fall would be a good place to look.
        Hope you are not in any hurry.
        JR
        • Gerald C.
          • June 30, 1987
          • 1283
          Joe,Anywhere I can get a picture of the first design buckets you are talking about?Thanks,Jerry
          • Gary F.
            • August 29, 2010
            • 248
            Jerry........PM me with an email address. I have about 30 pictures of them I can send you from my 63.
            • Jim B.
              • November 2, 2009
              • 43
              Gerald,
              I have a very nice LH fiberglass bucket but it is the second generation glass one that Joe Ray told you about. My '63 was built on 10/13/62 and had the first series. This is the only glass one I could find during my search in the late 80s so I wound up ordering metal ones from Chevrolet which were still available then. Have hung onto this blue one all these years thinking a match might show up some day but really haven't looked in several years. If interested, I will take some pictures and send them to you. The bezel is missing, but pivot arms, headlight back mounting bracket and wiring as I recall, are all there. I have no idea what a fair price would be but will be glad to send pics if it might help you. Good luck, jim
              • Loren L.
                • April 30, 1976
                • 4104
                Gerald, your situation is exactly what your free ad in the Driveline is for - many folks might be sitting on a fiberglass bucket, unwilling to part with it to a dealer, but willing to help a car owner out.
                • Frederick H.
                  • August 31, 1983
                  • 438
                  I have been fortunate enough to locate the correct version of a complete set of '63 headlight buckets (wiring, motors, etc.) except no bezels. At $2,100, I am having trouble justifying this for the points I might lose in a judging. Does anyone have a rough idea of current market value? Thanks.
                  • Gary F.
                    • August 29, 2010
                    • 248
                    Is your correct version based on your cars serial number?? , because there were many versions ( inside mounts, skins, bezels, etc. ). I found fiberglass buckets for mine, and luv them, why?. because that's what the car had when new. There was no points game in 63 when those cars were built with fiberglass buckets, why should there be one now? I spent $900.00 on a set with bezels, but no motors. As far as I'm concerned, it was money well spent. To each his own.
                    • Frederick H.
                      • August 31, 1983
                      • 438
                      Yes, the assemblies I am looking at are correct for my serial #. After serial# 14600 or so, the bezels attached from the bottom and top and tabs were added to the headlight housing sides. Very late cars did come equipped with the metal buckets (after SN 21000 or so). All this from the current 63-64 judging manual. My serial # ends in 11068. Correct 63 buckets are getting very hard to find. Thanks.
                      • Gary F.
                        • August 29, 2010
                        • 248
                        My serial number 10,862, and I found the right ones. Most people don't know the differences made to them along the way at the factory( screw mounting of bezels, eyebrows, color, etc. ) It's a journey within a journey, if you want correct. I just can't believe you'll put metal buckets on a 63 with your serial number. Please show more kindness toward your car, and give her back what she originally had.
