Radiator and fan shroud bolts - NCRS Discussion Boards
  • Doug R.
    • November 2, 2009
    • 65
    I am fast approaching the time to mount my new radiator and fan shroud in my 65'. I read the JG,but want to make sure of the bolt finish on both parts.What is the correct finish on the top stamped steel bracket and the six bolts on the shroud? Thanks
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Radiator and fan shroud bolts
    I believe they are all cad plated and mine are all stamped WB. The 6 bolts that hold the shroud in place have a large diameter flat washer and a lock washer. The 3 that hold the top bracket in place also have a large washer and a lock washer. This is on my 63 but I think they are the same.
      • 6958
      Doug, there is a similar thread below at bottom of page on the bolts and there plating. some mixed results though doe 65 on the bolt type. The steel bracket is painted semi gloss black.
      • Tony S.
        NCRS Vice President, Director Region VII & 10
        • April 30, 1981
        • 993
        Two different types of bolts documented with the fan shroud attachment bolts. Some pinchpoint (black phos), some flat (cad). The biggest problem I see when judging is that the typical repro bolts are way too long.
        Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
        Original member of the Kansas City Chapter, est'd 07/11/1982.
        Member: 1965 and 1966 National Judging Teams
        Judging Chairman--Kansas City Chapter.
        Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
        • Doug L.
          • March 14, 2010
          • 442
          My '64 was judged in January. I have cad plated, WB headmark bolts from LIC for that application. I lost points because they are too long. I think the JG says something about how far they should protrude through on the engine side. With that measurement you can probably calculate the total length they should be. I would calculate this length and call the various vendors and ask if they have that finish and headmark in the length you calculate. If you buy what they say is for that location, at least if it is from LIC, you will get bolts that are too long. I'm guessing that they have bolts of the correct length but listed for some other application. I have one shorter bolt with the same finish and headmark, which is installed the attachment hole at the lower radiator hose. The longer bolt hit the hose. Be careful at that location.
            • 6958
            I just had my original shroud bolts out of my 63 and they are WB1C head marks and are 3/4 in. thread lengths, Zinc plated. with black lock washers. I am sure that 65 were slightly different as Tony states. this is just for some of the guys that are searching this thread.
            • Daniel D.
              • December 9, 2009
              • 112
              • Tony S.
                • April 30, 1981
                • 993
                Here are a couple photos of the two types of '65 fan shroud bolts that we have documented on original cars. Hope this helps.
                Tony
                • Daniel D.
                  • December 9, 2009
                  • 112
                  In my previous post I mistakenly mentioned that the head mark letters WRB were spaced 180 degrees. They are spaced 120 degrees.
