1987 Corvette ignition key security - NCRS Discussion Boards
  • Ray G.
    • May 31, 1986
    • 1189
    Hello;
    Looking for a source for a resistor assortment to bypass the ignition key security problem.
    Occasionally we need to wait 2-5 minutes before engine will turn.
    Any help is appreciated.
    Thank YOU in advance.
    Ray
    I hope you dance
    • 43273
    Re: 1987 Corvette ignition key security
    Originally posted by Ray Geiger (9992)
    Hello;
    Ray
    Ray------
    You don't need an assortment. Simply measure the resistance of the pellet on your current ignition key and order the correct resistor. You can also make up a resistor with resistors from an electronics store. However, the below are more convenient.
    • Ray G.
      • May 31, 1986
      • 1189
      Thank YOU Joe.
      Was tipped off to a kit on line for less than $4. shipped.
      Your help is appreciated.
      Ray
      I hope you dance
      • Ray G.
        • May 31, 1986
        • 1189
        Hello Joe;
        Just an update. Found out by using a actually "key resistance" reader the resistor area of the key was worn, causing the VATS system to not read the resistance on a consistent basis.
        Thanks for your help, as always.
        Ray
        I hope you dance
        • Ken A.
          • July 31, 1986
          • 929
          Use a pencil eraser to clean the key.
          • Ray G.
            • May 31, 1986
            • 1189
            Thanks Ken.
            Turns out the resistor contacts wore down to the point they would only contact the VATS contacts in the ignition key lock assembly occasionally.
            I hope you dance
              • 43273
              Hello Joe;
              Ray
              Ray------
              You don't actually need a special key resistance reader. You can do it with a plain 'ol VOM, It's very easy. Just put the meter on resistance, zero it, and place the probes on either side of the resistance "pellet". Then, read the resistance value.
              • Keith B.
                • March 7, 2008
                • 928
                Is this the same for 94 as well. Mine does this ever so often. Today I could not start it for about 15 mins. Until it reset it self
                  • 43273
                  Keith------
                  Yes, exactly the same for 1994. If the problem is intermittent, it's likely the key or the sensor in the lock cylinder. If the car won't start, at all, it's likely either that the sensor has completely failed or the wires from the lock cylinder have broken. The latter can occur if work is done in the steering column in the area of the lock cylinder and the wires are not routed exactly properly.
                  • Keith B.
                    • March 7, 2008
                    • 928
                    Thanks Joe. Is the parts beside the key still available
                      • 43273
                      Keith------
                      The VATS sensor is integral with the lock cylinder. The lock cylinders are as follows:
                      GM #26033387-------6 speed
                      GM #26033390-------auto trans
                      The above are supplied with a key. Whether they can be re-keyed to use the existing key, I do not know. Also, if the key supplied with the lock cylinder is used and the pellet resistance is different than the original key (which is likely), I don't know how the computer is re-configured to accept the new resistance value.
                      • Keith B.
                        • March 7, 2008
                        • 928
                        Thanks again.
                          • 43273
                          Thanks again.
                          Keith------
                          I recall how this works now. The new lock cylinder is supplied with a key but the key is only used for key-cutting purposes, not for use in the car. After the lock cylinder is installed, key blanks of the original resistance value need to be purchased. Then, using the key supplied with the lock cylinder, the key blanks are cut. Now, one has keys with the correct cut AND the correct VATS resistance value to start the car.
                          Whether the new lock cylinder can be re-coded to enable it to use the original key, I do not know.
                          • Bill H.
                            • August 8, 2011
                            • 439
                            Keith------
                            Yep, that's how it's done.
                            The first thing to do is clean the key pellet on the key (alcohol works). This only helps once in a while.
                            Usually it's the lock cylinder, the C4 cylinders get some wear and tend to loosen up, the gap will widen between the lock bezel and the steering column will widen and you can loose contact between the sensor and the key pellet. If it gets loose enough, you'll also loose the chimes.
                            If you want just a new key, a good lock shop usually has them in stock. But they're pricy - $35 -$40 per key to have the resistance checked and the blank cut.
                            • Bill H.
                              • August 8, 2011
                              • 439
                              IIRC, the FSM states 10 minutes to reset the timer, I usually wait 15.
                              Note: If you try and restart before the 10 minute minimum, you will reset the timer and have to wait another 10.
