I purchased my 64 coupe from pictures on ebay. The car is beautiful except for the passengers side vent window hinge. The lower hinge must have broken and someone welded it back on. The weld looks very un professionable and is starting to rust. Do I need a whole vent frame with the hinge on or can it be fixed to go with the rest of the car? Thanks Ron
vent window frame hinge
Re: vent window frame hinge
The top hinge on the drovers side of my '67 was broken when I got it. It was a clean break. I found a local guy who welded it and polished it out. The repair was almost undetectable. I'm no expert, but I think the quality of the repair will be dependent upon the method of welding used, the proper filler rod, and mostly the skill of the welder.- Top
Ron,I purchased my 64 coupe from pictures on ebay. The car is beautiful except for the passengers side vent window hinge. The lower hinge must have broken and someone welded it back on. The weld looks very un professionable and is starting to rust. Do I need a whole vent frame with the hinge on or can it be fixed to go with the rest of the car? Thanks Ron
I believe Paragon Corvette fixes/repairs these frame hinges.Leif
Top Flight 2017 Lone Star Regional- Top
