C2 rear license light - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5338
    I need to repaint my rear 63 license light. I just can't guess the color. Anyone have a recommendation for a close match to the original color?
    Thank You
    Re: C2 rear license light
    Thank You
    Harry -
    Dull silver, as noted in the JG.
    • Harry S.
      • July 31, 2002
      • 5338
      John, Thanks
        • 6954
        Harry, I have a question not sure if you can answer regarding the difference on the trim parts reproduction assy verses the factory? at our local chapter I noted Joe S. pick up on one that was a Trim Parts repro. Is it the lens? I do have a original lens and a repro there is a slight difference, maybe something else? Thanks Ed
        • Harry S.
          • July 31, 2002
          • 5338
          The main difference is the bulb socket. On a original the bulb fits into a cut in the brass on a repro the bulb fits into a depression.
          Ignore the color on this one, look at the original socket.
            • 6954
            Harry,Thanks for the Info .
