1967 Tri-Power - NCRS Discussion Boards
1967 Tri-Power
  • Salvatore I.
    • April 1, 2004
    • 114
    1967 Tri-Power
    Hello Everyone:
    Was wondering if I could get some feedback on two minor questions:
    1. On the 67 Tri-Power 400 set up, do the attaching nuts that bolt the carbs to the manifold have washers, and if so, what kind of washers are they?
    2. Also, what is the torque spec?
    Thanks very much!
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: 1967 Tri-Power
    My answer will not pass judging but my carb bolts have the thin SS washers that hide under the nuts. That keeps the nut from digging in to the carb when being turned & keeps the torque even.
    The torque will change (loosen) as the gaskets take a set. Just don't initially over tighten when you install them and chech them about 3 times after each time the engine gets to temp.
    DOM
    • Salvatore I.
      • April 1, 2004
      • 114
      Re: 1967 Tri-Power
      Thanks Dom
      The car presently has no washers. It seems to warrant washers given the potential to have to adjust/tighten frequently....I assume the torque spec is 7 or 8 foot pounds?
      Thanks.
      • Domenic T.
        • January 29, 2010
        • 2452
        Re: 1967 Tri-Power
        Salvatore,
        That sounds about right (torque). I hide a lot of washers that are SS under fasteners, the washer diameter is small and the hole is exactly correct. I get them from a aircraft supply and they are either thick or thin and come in either SS or steel.
        They also work great under intake manifold bolts especially with aluminum manifolds.
        DOM
          • 15606
          Re: 1967 Tri-Power
          I like to use the torque specs given in the AIM. I would help you out, but I don't own a 1967 AIM.
          • Salvatore I.
            • April 1, 2004
            • 114
            Re: 1967 Tri-Power
            Thanks Terry
            • Michael F.
              • 745
              Re: 1967 Tri-Power
              84-120 lbs-in (inch pounds) for carb nuts or bolts according to 67 AIM
              Michael
              70 Mulsanne Blue LT-1
              03 Electron Blue Z06
              • Michael J.
                • January 27, 2009
                • 7128
                Re: 1967 Tri-Power
                I use a 1/4" drive ratchet and use only my index finger to tighten it. That has always worked, no leaks and better yet, no warped base plate.
                • Salvatore I.
                  • April 1, 2004
                  • 114
                  Re: 1967 Tri-Power
                  Thanks you all for the feedback...feel dumb since in the AIM per original there are no washers and torque spec is outlined...duh...
                  • Daniel Y.
                    • September 30, 2002
                    • 185
                    Re: 1967 Tri-Power
                    any washer will be a deduction for flight judging
                    Dan Young
                    65, 67 Duntov x2
                    66 bowtie x 2
                    71 LT1 TF
                    90 ZR1 McCelland
                    03 Anniverary
                    06 Z06
